WIP: Steve's Pershing Icon_minitimeby Shoveler74 Today at 6:03 am
WIP: Steve's Pershing Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
WIP: Steve's Pershing Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
WIP: Steve's Pershing Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
WIP: Steve's Pershing Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
WIP: Steve's Pershing Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
WIP: Steve's Pershing Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
WIP: Steve's Pershing Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
WIP: Steve's Pershing Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
WIP: Steve's Pershing I_vote_lcapWIP: Steve's Pershing I_voting_barWIP: Steve's Pershing I_vote_rcap
pzkpfw_steve
pzkpfw_steve
WIP: Steve's Pershing Empty
PostSubject: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeThu Aug 22, 2013 2:43 am
Here is A wip the Pershing i got on Tuesday afternoon:
WIP: Steve's Pershing DSCF0642_zps0d2e00fe
the camo scheme is inspired by my favourite tank camo from World of Tanks.
the paint job is not done yet.  still have a couple of washes to apply, some cans and ammo boxes to paint, and then i have some stencils prepared. plus the commander.
still having a heck of a time with the metal tracks.  one end of each track has the metal pin inserted with no next track in place, and every time i try to bang or tap the pin out, either the pin bends or the track deforms(because there is nothing along the pin holding it in shape)
i disconnected the smoker after running it briefly because of the terrible noise it made.  I also had to re-solder the antenna lead  because it had come lose.
at some point in the next month I'm also going to convert it over to IR instead of BB. and switch it to a clark board as soon as Curtis gets those in.
My Blog
WIP: Steve's Pershing Signature
Freakydude
Freakydude
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeThu Aug 22, 2013 8:57 pm
The paint is cool and I like it because it is different.  On Saturday we can show you how to take the pins out. Constant pressure is the trick. I don't recommend tapping or banging of any kind with those pins because they do deform so quickly.
You need not ever take them apart, the drive wheel is the trick to getting them on and off without seperating any links as well.
White Tiger
White Tiger
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeThu Aug 22, 2013 9:14 pm
You might want to run a Black wash over the tank to add a bit of grime! (Also that would be the WOT color scheme that makes my eye's bleed....lol)
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeThu Aug 22, 2013 11:58 pm
i will be running a blackwash. no worries there.  and i like the camo scheme specifically Because it makes your eyes bleed. also it's more fun to paint Very Happy
Curtis:  the tracks came not-connected(ie 1 long track length), so i need to pull a pin to connect them so i can even get to your stage with the sprockets...
My Blog
Freakydude
Freakydude
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeFri Aug 23, 2013 12:57 am
OK I didn't know that and if you posted it  that was my bad. We will get you fixed up mate, I have been there lots of times
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeSat Aug 24, 2013 6:14 pm
Took a few pics of the Pershing as it stands  at the battleday. give a decent view of how my Homemade stencils worked out.  Didn't get one of the Bridge class badge on the lower glacius though, so I'll have to get one of that another time.
WIP: Steve's Pershing DSCF0644_zpsb92a1f3e
WIP: Steve's Pershing DSCF0643_zpse5187922
I picked up some AK weathering effects, so I'll be adding some of that to the tank to mess it up a bit.
My Blog
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 2:21 pm
last night i got the bulk of the weathering done on the Pershing.
WIP: Steve's Pershing DSCF0650_zpsefaaa9a0
WIP: Steve's Pershing DSCF0649_zps5e826bd3
WIP: Steve's Pershing DSCF0651_zps712dc865
WIP: Steve's Pershing DSCF0652_zps868ad9f0
I use the AK interactive DAK weathering kit, with some dark green slimy grime, and some MIG enamel thinner.
these worked really well, and are fairly easy to use.  this was the trial run as i have never used these paints or techniques before. I'll describe it for people who have never used these techniques.
Basically, you cover the entire tank in the filter. this looks weird initially, but it gets better as you continue.  then you liberally apply the wash in areas you want darkened, such as handles, boats, seams, handles, engine deck, etc.  once the wash dries you brush down the entire tank in enamel thinner(or Minireal sprits, of whatever you wish to call it). this causes the wash to run and softens teh ard edge left by the initial wash.  it also creates rust/weathering streaks.
I then used the grime enamel paints(DAK streaking Grime and Slimy Dark Green Grime)brushed on  vertical lines along edges and around handles, bolts, anything that sticks out. once tehse dry you again brush down the entire areas you put the grime and it diffuses the lines and makes them look more like streaks.
these techniques work really well.  however you do need to pick your wash and filter carefully.  the DAK weathering kit works well for tanks painted on a light colored base (German tanks with camo based on Dunkelgelb, or my pershing etc)  but it won't work as well for vehicles that are panzer Grey, or standard Nato colours.  thre are specific weathering sets for panzer Grey and for NATO.  the NATO one is best used for colour schemes using greens and browns and darker camouflage. the Panzer Grey weathering set is best used for colour schemes that use predominantly greys.
all in all the AK products are easily worth adding to my painting "toolkit"
My Blog
Freakydude
Freakydude
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 4:07 pm
Hey Stephen
I ain't picky and I love your color scheme but yall gotta do that rear drive wheel lol it stands out like a sore thumb.  I think this work accentuated the wheels and rear deck real nice though
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 4:28 pm
yup, just need to get some car primer.  nothing else seems to stick to it properly.
My Blog
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 5:20 pm
Steve,
A little trick for painting metal parts, is to let them soak in water with a bit of dish soap and then rinse and dry.
It helps remove any oily film that might be on the part and helps the paint stick better.
I used Kryon paint my sprockets and haven't had any problems.
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 5:23 pm
yeah i do alot of miniature gaming, so I'm familiar with washing metal parts, although taht never seem to help.. i use krylon as well and am jsut not taht lucky.
My Blog
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 6:22 pm
Now it's starting to look like a well-loved tank... very nice work on the washes, and great detail work on the road wheels.
Tip for metal. Scrub them down with scotchbright / SOS pads, rough them up. Generally helps with any paint adhering.
PostSubject: Re: WIP: Steve's Pershing   WIP: Steve's Pershing Icon_minitimeWed Aug 28, 2013 8:28 pm
Sorry I forgot to say it was it has to be Dove dish soap.  Don't know why but it works the best.
