Servos  Question for Clarks Icon_minitimeby MikeC Today at 12:05 am
» For a laugh....
Servos  Question for Clarks Icon_minitimeby MikeC Yesterday at 10:18 am
Servos  Question for Clarks Icon_minitimeby Airbrushler Fri Sep 20, 2019 5:33 pm
Servos  Question for Clarks Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
Servos  Question for Clarks Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
Servos  Question for Clarks Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
Servos  Question for Clarks Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
Servos  Question for Clarks Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
Servos  Question for Clarks Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
Servos  Question for Clarks I_vote_lcapServos  Question for Clarks I_voting_barServos  Question for Clarks I_vote_rcap
Servos  Question for Clarks Empty
PostSubject: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 11:23 am
For my T-34 I'm planning on using a Clark board with servos for the elevation and for the recoil.
I'm a little uneducated when it comes to servos. Is there a certain type/size I should be looking for?
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 1:51 pm
Is it a WSN like mine ot the Torro?
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 6:13 pm
I went with the standard sub-micro, HS-55's. Usually between $10-20
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 6:25 pm
I think I used an HS-81 for Dean's T34.......
Servos  Question for Clarks <a href=Servos  Question for Clarks Wsn_t312" />
shiivers01
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 8:12 pm
Im actually running my elefant on those same servers and i will be adding one to my tiger. The movement looks a lot better.
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 8:51 pm
Is there a difference?
As far as I know they are the same copy of each other just under different names.
Oh, and was a WSN.
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 8:53 pm
Will these work okay? They sell them at the local hobby shop, for $5.
Servos  Question for Clarks TSG900-2T
Features
Dimensions: 22*11.5*27mm
Operating Speed (4.8V no load): 0.12sec/60 degrees
Stall Torque : 1.2kg / 42.3oz(4.8V);1.6 kg / 56.4oz (6.0V)
Temperature Range: -30 to +60 Degree C
Dead Band Width: 7usec
Operating Voltage:3.0-7.2 Volts
Original box: NO
Net weight: 14g
Package weight: 20g
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 9:01 pm
I just bought 4 of those for $20 too. Haven't use them yet but they will work I am sure. Same size as the HS-81 I used on the WSN.
BTW, I think WSN also sells the Tiger/T34 as static models but Torro is only RC.
Freakydude
Freakydude
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 9:07 pm
OK here is the skinny on servos for the Clark
2 types  Analog and Digital, for a Clark board - Who cares. The board don't, it's an equal opportunity user.
The two gear types are plastic and metal. Use metal if you can afford them as you get longer life out of them which equals less maintenance and they are much stronger and run truer.
Plastic gears strip when things come in contact with your barrel or your moving your tank around and you push it. if you are lucky and buy a name brand replacement parts are available or you can buy servos for 5 bucks and just replace them.
Think that is a bad thing? sometimes no because the teeth of the servo can act as a safety- meaning that when something does hit your barrel its much easier to replace a $5 servo than all the guts etc holding the barrel in.
Stince  That servo will work fine but when you buy it make sure it comes with arms.
Me i switched to metal servos but that is because I am a dumb azz and keep forgetting to turn my KT barrel sideways when I go through ditches, stripped 3 servo already this year lol
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 9:54 pm
Thanks for the info Curtis, I'll try to get out to the hobby shop this weekend and maybe see what they have that I can use for the steering for the Half-track too.
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 9:56 pm
Curtis that just means your barrel is too big... I know I knew, I can hardly believe it too...
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 10:53 pm
Hey Curtis, the HS-55 or HS-81 are only plastic gears, right ? I mean unless you go for the $30 jobs you won't get metal gear, no ? If it is all plastic anyway, I would take the no name $5 instead of the $15 HiTec ones.
Freakydude
Freakydude
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeThu Aug 29, 2013 11:12 pm
Mike I have 9.99 tower pro servos in stock, they are metal gear servos
If all you guys want I can mass an order from each of you in the same pot and get them for like 6 or 7 bucks including shipping costs. It will take about 2 weeks to get here but they are great metal geared servos. About the same size as the HS81 but I can get a micro version for the same cost for those little tanks we all have.
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 12:38 am
Alright Curtis, bring me couple when we meet up and I will try them out. They look and measure slightly bigger than the Tower Pro SG-90 and the HS-81. Do they have a stronger pull ?
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 1:56 am
hehehe or going through Stince's Barn
Servos  Question for Clarks Soviet10
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 1:59 am
Curtis i won a HiTec HS-425BB Servo Deluxe with dual ball bearings would that be good for a recoil
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 6:34 am
Thats a nice servo, good price too @ servo city for $12.99. Too bad their shipping is insane...
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 7:58 pm
yes i won a bunch of stuff the
- HiTec – HS-425BB Deluxe Servo
- 1 Lipo Storage Bag
- 4in1 Hex Driver
- 50 pcs 1/8" Heat Shrink Tubing
- (2) 9x1 Dual Lock Velcro Strips
- (3) 9x1 3m 2 sided Foam Tape
- White RCC Tshirt
- RCC Lanyard
it was awesome
Freakydude
Freakydude
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 8:37 pm
yes it would work just make sure you set your end point adjustments. A full 180 deg of turn is actually what you don't want for recoil as the servo can move too much. It will be smooth as silk though once you get your distances done and set
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeFri Aug 30, 2013 10:07 pm
Hi Curtis did you mean the one i have or the one Derek is thinking is the speed on this one a good thing it has a 0.21 sec/60degrees AT 4.8 volts
PostSubject: Re: Servos Question for Clarks   Servos  Question for Clarks Icon_minitimeSat Aug 31, 2013 9:05 am
sorry i just read this post again ....my last post was based on one of my i just woke up from falling asleep at the computer things...lol thanks for your answer Curtis
