WSN vs HL T34-85 Icon_minitimeby Negaduck Today at 8:01 pm
» For a laugh....
WSN vs HL T34-85 Icon_minitimeby MikeC Today at 10:18 am
WSN vs HL T34-85 Icon_minitimeby Airbrushler Yesterday at 5:33 pm
WSN vs HL T34-85 Icon_minitimeby Strato50 Wed Sep 18, 2019 8:49 pm
WSN vs HL T34-85 Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
WSN vs HL T34-85 Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
WSN vs HL T34-85 Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
WSN vs HL T34-85 Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
WSN vs HL T34-85 Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
WSN vs HL T34-85 I_vote_lcapWSN vs HL T34-85 I_voting_barWSN vs HL T34-85 I_vote_rcap
 WSN vs HL T34-85
Freakydude
Freakydude
WSN vs HL T34-85 Empty
PostSubject: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 1:49 pm
Take a look at the differences between the Tanks. Apparently I am still picture challenged so just go to the link
https://s220.photobucket.com/user/AggyCo/library/?sort=3&page=1
Freakydude
Freakydude
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 1:54 pm
I have both tanks and really there is very little difference from a straight out of the box look. The HL is higher but within reason and that was done to cover the gearbox inside. It doesn't appear able to take other gearboxes but I will look into that later when I have more time. The smoker unit is wedged inbetween the motors which is a good spot for it as this tank would look good with smokers that work.
All in All a pretty decent tank and I do think the HL version has a slight advantage in the mold department as this little guy actually is quite detailed.
The WSN has the proper look though so this is 6 of one and a half dozen of the other.
tomzag
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 4:18 pm
Thank you for the comparison, it is really good to know.
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 5:02 pm
On first glance the comparison can go a lttle further in the definition of the model. The HL is a model 1943 turret. The WSN is a flattened model 1944 turret. This allows you to do 2 different time periods. Which means on the HL the gun mantle is wrong but I think it could be changed pretty easy.
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 5:20 pm
I noticed that the smoker is not attached to the upper hull like the Taigen KV-1s....... How are you suppose to connect them after pulling the top off ? Also I believe the HL one has painted rubber road boggies and the WSN one is actual rubber.
The biggest difference in mind is the material. WSN RC version turret is softer translucent plastic painted over and HL is your usual injection molded.
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 11:04 pm
oooooooooooooooh plastic gears that sucks
WSN vs HL T34-85 Soviet10
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSat Oct 05, 2013 11:06 pm
actually they look like Panther Gearboxes
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSun Oct 06, 2013 12:08 am
Dean what are the major turret differences? I don't see a HECK of a lot between the two... Razz *opens can of worms*
Curtis do you mean other BRANDS of gearboxes? I would want to put the steel HL regular ratios in there.
Anyway, looks sexy. Nice work on the body paint & weathering on the tracks. Cool!
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSun Oct 06, 2013 12:16 am
Curtis can you do a video of this HL T-34 in action show the turret left and right elevation i have plans for lowering the suspension already in mind does it have rubber road wheels or just painted plastic the turret looks better to me it don't look like it has that wierd split in the sides
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSun Oct 06, 2013 12:19 am
oh another question is what hatches open and don't open on the HL T-34
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSun Oct 06, 2013 12:34 am
Check out what this guy did to the HL T-34
3rd page of pics show the suspension 'mod' Razz
Pics from : photobucket.com/user/Smudgyboy/slideshow/Heng%20Long%20T34
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSun Oct 06, 2013 9:21 am
Like I said, on first glance. Next battleday we can compare then side by side with mt ref. pics
PostSubject: Re: WSN vs HL T34-85   WSN vs HL T34-85 Icon_minitimeSun Oct 06, 2013 11:52 am
I think that angle split on the side of the turret is part of what Dean's talking about. The WSN one is a late/post WWII production with the angle weld line, and the HL one is WWII I believe. I think the HL one should have the early road boggies as well as the cut-out boggies wasn't really used in WWII either.
WSN vs HL T34-85
