how do i create shell hits Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
how do i create shell hits Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
how do i create shell hits Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
how do i create shell hits Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
how do i create shell hits Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
how do i create shell hits Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
how do i create shell hits Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
how do i create shell hits Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
how do i create shell hits Icon_minitimeby Airbrushler Sat Sep 07, 2019 8:15 pm
how do i create shell hits I_vote_lcaphow do i create shell hits I_voting_barhow do i create shell hits I_vote_rcap
doug818tiger
how do i create shell hits Empty
PostSubject: how do i create shell hits   how do i create shell hits Icon_minitimeFri Oct 11, 2013 9:24 am
Well the topic title says it all how do I create a shell impact to make it look like a impact or a graze off the glasis plate
PostSubject: Re: how do i create shell hits   how do i create shell hits Icon_minitimeFri Oct 11, 2013 9:55 am
For "splashes" that is what hits that graze off are called, or the fragments that melt on impack I just use my soldering gun at lower temp and a pointed tip on an angle. For actual penetration hits the trick I use is use a dull point to push the plastic in at low temp and then from the back side sand it till a hole develops this way you can decide how big or how small the shell was. I will bring my KT and show you if you want. It has examples of hits, dings, splashes etc...
PostSubject: Re: how do i create shell hits   how do i create shell hits Icon_minitimeFri Oct 11, 2013 9:58 am
On my Tiger I heated up a round bullet-type connector with a small torch, and pushed it into the plastic at different angles to get different types of shell impacts & bounces, turned out really well.
You could pretty much use any piece of metal in whatever shape you want.
how do i create shell hits Yellow%20bullet
doug818tiger
PostSubject: Re: how do i create shell hits   how do i create shell hits Icon_minitimeSat Oct 12, 2013 8:16 pm
Cool thanks guys I had the right ideas then I was going to make a die out of steel and then heat it and push it into the plastic going to test some ideas including the ones you guys mentioned
