» Miscellaneous Images 2024
WANTED: Pinion Gear Icon_minitimeby Abteilung 506 Yesterday at 10:26 pm
WANTED: Pinion Gear Icon_minitimeby Abteilung 506 Yesterday at 9:42 pm
WANTED: Pinion Gear Icon_minitimeby dgsselkirk Yesterday at 9:13 pm
» Hello new here
WANTED: Pinion Gear Icon_minitimeby MikeC Yesterday at 5:38 pm
WANTED: Pinion Gear Icon_minitimeby dgsselkirk Wed Mar 27, 2024 2:04 pm
» 2024 CLUB DUES.....
WANTED: Pinion Gear Icon_minitimeby dgsselkirk Wed Mar 27, 2024 1:07 pm
» Taigen KV metal swing arms
WANTED: Pinion Gear Icon_minitimeby MikeC Sat Mar 23, 2024 6:10 pm
WANTED: Pinion Gear Icon_minitimeby Hammertime999999999 Sat Mar 23, 2024 1:41 pm
» HERITAGECON 2024
WANTED: Pinion Gear Icon_minitimeby Negaduck Fri Mar 22, 2024 7:38 pm
WANTED: Pinion Gear I_vote_lcapWANTED: Pinion Gear I_voting_barWANTED: Pinion Gear I_vote_rcap
Bktanker
 WANTED: Pinion Gear
WANTED: Pinion Gear Empty
PostSubject: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 10:10 am
Hi Guys,
help  I need a pinion gear for a standard Heng Long motor. help
The one I have, the hole in the pinion is too big and keeps wandering along the motor's shaft and lose contact with the first gear. No
doug818tiger
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 10:23 am
Hey man I have a pluthra of pinions I also have harbour shaft shim stock to take up any excessive play say if you have a metric motor and a standard pinion ...letme know
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 10:30 am
Hi Guys,
What if you were to put some Loctite on the shaft were the gear is supposed to sit. Loctite 262 will seal to metal
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 11:32 am
WANTED: Pinion Gear Doh
Loctite!!!  Why didn't I think of that?
I'll give it a try tonight.
doug818tiger
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 3:21 pm
I wouldn't use loc tite tread locker but I would use there retainer compound for bearing surfaces its green in color and its made by loc tight also
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 3:24 pm
Loctite 620
Bearing & Shaft Retaining Compound
•Color: Green
•Viscosity: 8500
•Excellent retaining and sealing compound
•Ideal to fill gaps up to 0.015”
•Excellent for slip fitting parts.
•Withstands working temperatures up to 450 º F
•Temperature Range: -65° to 450° F
•Fix Time: 30 min
•Cure Time: 24 hrs
•Usage: High Strength, Press Fit
Freakydude
Freakydude
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 4:21 pm
loctite may not be the solution, I have a few of the standard HL pinions around if you need them. just let me know
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 4:26 pm
I have some loctite at home, I'll try tonight and see how it works, If it doesn't then I'll take you up on the offer Curtis.
PostSubject: Re: WANTED: Pinion Gear   WANTED: Pinion Gear Icon_minitimeTue Nov 26, 2013 4:28 pm
Make sure you use the Bearing locker type. I have used that product in my Pro-street Cuda to hold the rear axle bearings in place. If it can hold those, it certainly should be able to hold your gear.
WANTED: Pinion Gear
» Wanted: Mato Panther Gear Boxes
» wanted 2.4 Ghz HL Board
» Heng Long gearbox motor pinion
» Parts Wanted
» Wanted - RX-18
Can-Am RC Tank Club :: The Quartermaster's Depot :: Looking to Buy-
