» Miscellaneous Images 2024
Barrel elevation servo placement? Icon_minitimeby Abteilung 506 Yesterday at 10:26 pm
Barrel elevation servo placement? Icon_minitimeby Abteilung 506 Yesterday at 9:42 pm
Barrel elevation servo placement? Icon_minitimeby dgsselkirk Yesterday at 9:13 pm
» Hello new here
Barrel elevation servo placement? Icon_minitimeby MikeC Yesterday at 5:38 pm
Barrel elevation servo placement? Icon_minitimeby dgsselkirk Wed Mar 27, 2024 2:04 pm
» 2024 CLUB DUES.....
Barrel elevation servo placement? Icon_minitimeby dgsselkirk Wed Mar 27, 2024 1:07 pm
» Taigen KV metal swing arms
Barrel elevation servo placement? Icon_minitimeby MikeC Sat Mar 23, 2024 6:10 pm
Barrel elevation servo placement? Icon_minitimeby Hammertime999999999 Sat Mar 23, 2024 1:41 pm
» HERITAGECON 2024
Barrel elevation servo placement? Icon_minitimeby Negaduck Fri Mar 22, 2024 7:38 pm
Barrel elevation servo placement? I_vote_lcapBarrel elevation servo placement? I_voting_barBarrel elevation servo placement? I_vote_rcap
Bktanker
pzkpfw_steve
pzkpfw_steve
Barrel elevation servo placement? Empty
PostSubject: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeMon Feb 17, 2014 12:02 am
anyone have any tutorials or pics of how to place a servo for barrel elevation?
Cheers,
Steve
My Blog
Barrel elevation servo placement? Signature
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeMon Feb 17, 2014 3:18 am
It can be tricky but usually you just need to be a bit creative and skillful with a hobby knife or dremel.
Which tank are you considering?
The simplest way is to gut and cut away most of any stock airsoft parts and glue a servo to the side of the unit wherever it fits best, then use the roof of the turret as the anchor point for the control arm. Adjust as necessary Smile
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeMon Feb 17, 2014 9:25 pm
Here is a pic of what one guy over on RCU did with his T-34. He also used a servo for the recoil too.
Barrel elevation servo placement? 3ZPpYcd
Freakydude
Freakydude
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeMon Feb 17, 2014 10:36 pm
Steve just put the servo gear that turns the arm as far back as possible. It will help keep the barrell striaght and keep a nice movement.
I always just cut a slot in the BB mechanism wall ( after gutting it ) and slide a servo into the slot. I prefer to have my servos laying on their side rather than standing up. That way the servo bottom does not go down into the tank when you have the gun elevated. I use all the space in my lowers that I can
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeThu Feb 20, 2014 2:24 pm
i am setting it up inside a pershing.  lots of room in the turret.also installed the new upper hull board Ian Graciously gave me, and installing the IR emitter.
My Blog
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeThu Feb 20, 2014 3:57 pm
New upper hull board????   scratch
What's that?
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeThu Feb 20, 2014 6:44 pm
the upper hull board is the little board with the 8pin header that the 8 pin connector goes to from the main board.that connects headlight LEDs, turret rotation, etc. it's usually screwed into the top part of the hull.
My Blog
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeFri Feb 21, 2014 3:04 pm
Okay, now I know what board your talking about.
real_hulu
real_hulu
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeFri Feb 21, 2014 4:17 pm
OK, I just wondering where I can get this kind of little connecting linkage?
Barrel elevation servo placement? Db10
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeFri Feb 21, 2014 4:45 pm
Any local RC hobby shop should have it.
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeFri Feb 21, 2014 5:47 pm
In order of where I would go Grand River Hobbies Kitchener, Flight Craft Victoria Street out toward Guelph, Forbes Hobbies Cambridge
pzkpfw_steve
pzkpfw_steve
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeFri Feb 21, 2014 5:52 pm
i jut made one out of steel wire that coincidentally fits snugly in the hole in the servo arm.  bent it in 2 places, and the other end fits loosely in a hole in the piece of the airsoft housing i left in place.
My Blog
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeFri Feb 21, 2014 10:21 pm
Meh..., if it works, it works! Must be Russian tank...LOVE IT! Very Happy  russian
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeSat Feb 22, 2014 4:06 pm
screws, nuts and styrene works well in my tiger setup
Barrel elevation servo placement? 003_zps29a9ad24
tomzag
PostSubject: Re: Barrel elevation servo placement?   Barrel elevation servo placement? Icon_minitimeSat Feb 22, 2014 8:18 pm
woa! what a nice setup! Ros!
» Servo Elevation
» How To - BB to Servo Recoil
» Servo recoil on Tamiya Electronics
» Elevation?
» Wiring guide for setting up an HL recoil system and elevation
