Reaper332 Sgt-Major
| Subject: Reapers Hummel Wed Aug 07, 2013 4:35 am | |
| Subject: Re: Reapers Hummel Wed Aug 07, 2013 8:09 am | |
| i always like the Hummel and the Wespe can't wait to see what you do to it and when you finish it _____________________________________________ |
tomzag Second Lieutenant
| Subject: Re: Reapers Hummel Wed Aug 07, 2013 10:25 am | |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 2:37 am | |
| Thanks guys.....
Nice Hummel Tomzag, can I ask how you did the recoil and elevation/traverse in the one you did.
Cheers Ken |
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 11:00 am | |
| Ken, It was sold long time ago. otherwise i can take some pictures inside.
All gun traverse, elevation and recoil were hiden inside the hull. the traverse, attach an arm to the axle undermeath the hull, so you use servo to pull it back forth. gun elevation is the easiest, a servo underneath pull the arm through a hole, the arm attached to the gun bottom. the recoile is the hardest, you have to drill a hole in the rod which connect the gun bottom and hull, there is a wire pulling the gun back through two roller hiden inside the gun. when the recoil unit recover, the spring in the gun push the gun back to original position. hard to explain, it is easier to show you in person. |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 5:15 pm | |
| Thanks Tomzag, I am not sure if mine will recoil yet definately doing traverse and elevation. Hopefully mibe well turn out as nice as yhe obe you did. Cheers Ken |
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 5:27 pm | |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 6:48 pm | |
| Nice I like that. So I should plate both sides and the bottom on the inside. I see also you used the working suspension is it any good.
Cheers Ken |
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 6:55 pm | |
| suspension from kk is ok, but need work to make them not wigglely. the road wheels and return rollers got to be replaced by metal ones. check ebay and see if you can find them. I still have one set if you are interested. |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 7:07 pm | |
| most definitely interested mate.... how much do you want for them and will they go on tje standard suspension...? |
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 7:08 pm | |
doug818tiger Sgt-Major
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 9:47 pm | |
| Very nice how is the build as for parts fitting correctly and parts finish ...I know from some of my former tamiya kits I have done sometimes they can get a little sloppy on flashing or miss alighned parts ..just asking basicly ....quality....... |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Thu Aug 08, 2013 11:38 pm | |
| - doug818tiger wrote:
- Very nice how is the build as for parts fitting correctly and parts finish ...I know from some of my former tamiya kits I have done sometimes they can get a little sloppy on flashing or miss alighned parts ..just asking basicly ....quality.......
Hey mate I have found it to be pretty dam good actually and was a bit surprised of how good it was and how good the parts fitted together. |
| Subject: Re: Reapers Hummel Thu Aug 15, 2013 11:49 pm | |
| Just sold my nashorn. It is gone, i can not afford to keep it. |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Sat Aug 17, 2013 4:15 am | |
| Sorry to hear that Tom, it was very nicely done. Well Everyone I have done some work to the Hummel over the last couple of days. The upper hull is finished, the gun assembly is yet too be finished as is the lower hull just waiting on some parts to turn up... ( Thanks Tom ) Here are a couple pics of it mocked up with the standard gearboxes while I am awaiting for parts to arrive. Cheers Ken |
| Subject: Re: Reapers Hummel Sat Aug 17, 2013 7:13 am | |
| really nice, realy nice. pls check the tracking number in paypal. |
| Subject: Re: Reapers Hummel Sat Aug 17, 2013 10:48 am | |
| what a beauty, Great job now i want one...one day _____________________________________________ |
| Subject: Re: Reapers Hummel Sat Aug 17, 2013 1:03 pm | |
| Can't wait to see it with some paint, good job so far! _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Sat Aug 17, 2013 5:07 pm | |
| Thanks guys its fast becoming my favourite tank...... Thanks Tom yeah already tracking the parcel you sent...... |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Fri Aug 23, 2013 6:27 pm | |
| The parts from Tom turned up yesterday...... they are fantastic and he gave me heaps of parts so a HUGE thank Tom for everything. Also the parts from Daryl Turner turned up as well so the build can move on now................ Cheers Ken |
| Subject: Re: Reapers Hummel Fri Aug 23, 2013 6:34 pm | |
| Oh wow.. what is all that stuff in the lower pic? _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Reapers Hummel Fri Aug 23, 2013 6:56 pm | |
| don't forget to keep it refrigerated...lol _____________________________________________ |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Fri Aug 23, 2013 8:01 pm | |
| Hey Strato the parts in the lower pic are a gearbox plate to mount Tamiya gearboxes in it and drive shaft adapters and the other is a spring loaded idler set up. I have another set of these coming as I just brought another brand new in the box Hummel cheap and going to maybe make a Nashorn ( Inspired by Tom's ) out of it. Airbrushler you noticed the box.... |
| Subject: Re: Reapers Hummel Fri Aug 23, 2013 8:22 pm | |
| yep i did...hehehe i think Strato was wondering what all those disks were in the smaller box look like metal road wheels _____________________________________________ |
Reaper332 Sgt-Major
| Subject: Re: Reapers Hummel Fri Aug 23, 2013 9:57 pm | |
| Oh yep they are the metal road wheels and in the packet are the metal return rollers. |
| Subject: Re: Reapers Hummel | |
