SLU Wiring problems Icon_minitimeby Shoveler74 Today at 6:03 am
SLU Wiring problems Icon_minitimeby hachleopard2 Sat Sep 14, 2019 7:23 pm
SLU Wiring problems Icon_minitimeby Jarlath Fri Sep 13, 2019 4:04 pm
SLU Wiring problems Icon_minitimeby Strato50 Wed Sep 11, 2019 10:50 pm
SLU Wiring problems Icon_minitimeby treemagnet Tue Sep 10, 2019 5:15 pm
SLU Wiring problems Icon_minitimeby Strato50 Tue Sep 10, 2019 3:29 am
SLU Wiring problems Icon_minitimeby knispel Tue Sep 10, 2019 1:21 am
SLU Wiring problems Icon_minitimeby Negaduck Sun Sep 08, 2019 5:09 pm
SLU Wiring problems Icon_minitimeby Strato50 Sat Sep 07, 2019 9:30 pm
SLU Wiring problems I_vote_lcapSLU Wiring problems I_voting_barSLU Wiring problems I_vote_rcap
 SLU Wiring problems
Go to page : 1, 2  Next
TeTris MoNk
TeTris MoNk
SLU Wiring problems Empty
PostSubject: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 12:33 am
So I made a huge mistake with installing the SLU. I didn't take notes or pictures of some of the wiring to the turret motors. Now I'm stuck and afraid to do anything Embarassed
SLU Wiring problems IMAG0652
SLU Wiring problems IMAG0651
SLU Wiring problems IMAG0650
If anyone can tell me where to solder the reds and blacks to these motors I'll be forever in your debt!
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 1:32 am
I believe with the turret motor it doesn't matter so much. If you attach the wires the wrong way your turret will just rotate the opposite direction. To fix it just switch the plugs on the ESC board. I'm sure Hulu or Tim can confirm this.
Is the other motor an airsoft or recoil?
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 1:34 am
Airsoft.... Not that i was gonna use it or anything
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 2:16 am
SLU Wiring problems PDR_1876
sorry TeTris
just trying to find good batteries to even get the camra to work i covered my exposed wires all with hotglue cause that's what happened to my SLU two wires touched and fried a chip
mines a recoil
red wire on the top
SLU Wiring problems PDR_1877
real_hulu
real_hulu
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 9:14 am
Frankly, I don't know... Embarassed
I just try it first before I solder it
Fireman Tim
Fireman Tim
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 2:54 pm
Yes, you can wire the turret traverse and barrel elevation motor either way. If you get the polarity backwards, just reverse the way you plug it into the ESC.
As for the airsoft, the SLU connects to it opposite of the polarity that Heng Long did it.
If you need help getting it finished, I can spare a few minutes tomorrow.
of the Pan-Tiger Panzer Div.
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri May 18, 2012 4:38 pm
I will bring my solder station to help, if I can.
If any one needs wires for there tanks (red black) I have a lot of cut offs people can have (3 feet long ++) I will try to remember to bring some.
The Great Pan-Tiger pirat
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 1:21 pm
I got the 400 motors and Steel Gearboxes finally. Wired everything up and finally.... FINALLY!!! finished installing the SLU... but as Tim can attest for this, the Hobby King controller is messed up six ways sideways with the throttle.
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 6:52 pm
what's it doing now
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 7:02 pm
I tested it off ground and realized one of the motors is turning the opposite way when driving foreward... Do I resolver the wires the otherway?
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 7:07 pm
yep switch the wires on the one going backwards when you are on throttling forwards
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 7:16 pm
Roger that! Thought Phil had it on right... I just copied where the previous wires were when I got it... But on the brightened this thing is zippy!
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 7:20 pm
so you got it switched and working now
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 7:36 pm
Not yet. When I get home I'm gonna switch it. But while I was playing with the controller trying to figure it out it was zipping around side to side like a psycho
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 9:58 pm
Me and Greg had the same thing happen to us when we hooked up ours to the Panzer III and T-34. We used the same set-up as the HL and we both had to switch the wires around on one of the motors.
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 10:05 pm
Well its running now but i have yet another wire reversed... the turret rotation >.<
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 10:11 pm
Yea mine was backwards too when I spliced it in with red - red and black - black. Just reverse it at the ESC, done and done Smile
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 10:22 pm
Just unplug it from the ESC and plug it back in the other way around, it will reverse it.
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeThu Jun 07, 2012 10:56 pm
The amount of times I've unscrewed this tank I swear I should keep the hulls together by magnet..... Thanks guys Very Happy
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri Jun 08, 2012 2:52 am
Magnets are a good idea, I have a stack of em that i WAS going to use before I got the miracle asiatam hulls.. lol.
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri Jun 08, 2012 3:39 am
that's where i am leary about the magnets and the Electronics
not too sure they go good together
might screw up the electronics so i think i would stay away from them
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeFri Jun 08, 2012 4:48 am
This crossed my mind as I casually placed my loose speaker atop the ESC... It has since been moved.
TeTris MoNk
TeTris MoNk
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeSun Jun 10, 2012 10:03 pm
Tested the Bulldog today in my field... along with the indoor ready M1A2 Abrams
https://www.youtube.com/watch?v=DY2A3kOfHYU&feature=plcp
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeSun Jun 10, 2012 10:32 pm
looks like it's running pretty good now
PostSubject: Re: SLU Wiring problems   SLU Wiring problems Icon_minitimeSun Jun 10, 2012 10:54 pm
It looks pretty quick!! Shocked
You'll have to take the bulldog off the side and put on a road runner. beep, beep! Wink
SLU Wiring problems
