Battery Connector  Icon_minitimeby MikeC Yesterday at 11:36 pm
Battery Connector  Icon_minitimeby MikeC Yesterday at 11:31 pm
Battery Connector  Icon_minitimeby dgsselkirk Yesterday at 6:31 pm
Battery Connector  Icon_minitimeby dgsselkirk Yesterday at 2:20 pm
Battery Connector  Icon_minitimeby Jarlath Wed Apr 17, 2024 3:46 pm
Battery Connector  Icon_minitimeby Hammertime999999999 Tue Apr 16, 2024 9:55 pm
Battery Connector  Icon_minitimeby MikeC Thu Apr 11, 2024 6:01 pm
» Work an Play Day April 6th!
Battery Connector  Icon_minitimeby Hammertime999999999 Wed Apr 10, 2024 6:39 am
» Dragon 1/6 M4 Sherman 76mm
Battery Connector  Icon_minitimeby MikeC Mon Apr 08, 2024 10:09 am
Battery Connector  I_vote_lcapBattery Connector  I_voting_barBattery Connector  I_vote_rcap
Hilario
 Battery Connector
Al.M
Al.M
Battery Connector  Empty
PostSubject: Battery Connector    Battery Connector  Icon_minitimeMon Nov 02, 2015 1:28 pm
Just wondering what battery conectores everyone uses? Tamiya, deans or what have you. Does the club try to get everyone to use the same or is it all personal preference?
King Tiger, Sherman. All under construction. 👍Now also T34/85
PostSubject: Re: Battery Connector    Battery Connector  Icon_minitimeMon Nov 02, 2015 2:14 pm
Your own preference. I use Tamiya, some guys use deans...
PostSubject: Re: Battery Connector    Battery Connector  Icon_minitimeMon Nov 02, 2015 2:23 pm
If I have to do it all over again, I would pick out my battery first from HobbyKing and see what it comes with and go with that. However, since Heng Long uses large Tamiya plug, there is always parts for it.
I am on large Tamiya, and have just about every connector converter from HobbyKing (Deans, HXT 4mm, XT-60 etc etc to Tamiya).
MichaelC.
Al.M
Al.M
PostSubject: Re: Battery Connector    Battery Connector  Icon_minitimeMon Nov 02, 2015 7:04 pm
Ok. Thank you guys.
PostSubject: Re: Battery Connector    Battery Connector  Icon_minitimeTue Nov 03, 2015 4:55 pm
I stick with Tamiya because that's what's on the batteries I order & what tanks are set up with default. It's easy to get and even a parts-donor HL tank has that power switch ready to go!
PostSubject: Re: Battery Connector    Battery Connector  Icon_minitimeTue Nov 03, 2015 5:36 pm
Jordan, do you use lipo or big butt NiMHs ? The only reason I bought all these bloody converters is because the lipos I get from HobbyKing never have Tamiya connectors....... Even JST, but not Tamiyas. With the converter it makes the whole battery thing quite a cable full in the hull.
PostSubject: Re: Battery Connector    Battery Connector  Icon_minitimeWed Nov 04, 2015 7:39 am
Yea I stick with 5000mAh NiMH, I like to keep it simple for the most part. Every % drop in chance of explosion is worth it Wink
Battery Connector
» HL 8 Pin Connector Needed
» Battery Question?
» Battery type?
» Solder Seal Wire Connector
» Can-Am Battleday October 15th, 2016
