Making my own Real Rust Icon_minitimeby Hammertime999999999 Today at 6:11 am
» Hello new here
Making my own Real Rust Icon_minitimeby Abteilung 506 Today at 12:13 am
Making my own Real Rust Icon_minitimeby dgsselkirk Yesterday at 11:59 pm
Making my own Real Rust Icon_minitimeby dgsselkirk Yesterday at 2:04 pm
» 2024 CLUB DUES.....
Making my own Real Rust Icon_minitimeby dgsselkirk Yesterday at 1:07 pm
» Taigen KV metal swing arms
Making my own Real Rust Icon_minitimeby MikeC Sat Mar 23, 2024 6:10 pm
Making my own Real Rust Icon_minitimeby Hammertime999999999 Sat Mar 23, 2024 1:41 pm
» HERITAGECON 2024
Making my own Real Rust Icon_minitimeby Negaduck Fri Mar 22, 2024 7:38 pm
» New member
Making my own Real Rust Icon_minitimeby Hammertime999999999 Fri Mar 22, 2024 2:58 pm
Making my own Real Rust I_vote_lcapMaking my own Real Rust I_voting_barMaking my own Real Rust I_vote_rcap
Bktanker
Go to page : 1, 2  Next
Making my own Real Rust Empty
PostSubject: Making my own Real Rust   Making my own Real Rust Icon_minitimeSun Dec 06, 2015 7:02 pm
using a sos pad letting it rust bit by bit to make my own real rust powder
Making my own Real Rust Wp_20111
Making my own Real Rust Wp_20112
Making my own Real Rust Wp_20113
Making my own Real Rust Wp_20114
Making my own Real Rust Wp_20115
Making my own Real Rust Soviet10
Reaper332
Reaper332
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeSun Dec 06, 2015 7:15 pm
Nice work mate..... very cool
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeSun Dec 06, 2015 7:20 pm
Thanks Brother took a while to make just what you see...lol
Reaper332
Reaper332
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeSun Dec 06, 2015 7:30 pm
Yeah I bet .... going to do up the step by step pics today on the rust technique I did on the JT
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeSun Dec 06, 2015 7:38 pm
That's cool cause they look real , Awesome job
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeMon Dec 07, 2015 5:56 am
What did you use to set the rust? Just a mat varnish?
King Tiger, Sherman. All under construction. 👍Now also T34/85
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeMon Dec 07, 2015 8:11 am
yep just the frosted clear we use to clear the tanks just sprayed some in a tuna can and dipped the brush in the clear to pick up the rust to apply
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeTue Dec 08, 2015 8:17 am
Ok. Im not familiar with the frosted clear you are speaking of.
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeTue Dec 08, 2015 10:15 pm
they have it at Canadian tire you have to read on the side to make sure it's the clear they have another that has a hint of green in it
Making my own Real Rust 16c45810
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeWed Dec 09, 2015 5:41 am
Ok. Great. Thank you. I will give it a try. That's probably why i couldn't match the effect on the T34.
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeWed Dec 09, 2015 8:52 am
Are you using it as a clear coat?
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeWed Dec 09, 2015 10:17 am
Not sure who that was aimed at kaptain but if it is me. Should I not?
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeWed Dec 09, 2015 1:23 pm
Greg, do you use this as a flat coat or a sealant ? Does it chemically melt anything ?
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeWed Dec 09, 2015 7:53 pm
I've used that too and it's not bad, it adds a matte finish.
I thinkkkkk I've had it bubble on me a tiny bit but I cannot be sure.
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeWed Dec 09, 2015 8:28 pm
i use it on my whole tanks to seal it but this tank was already done with the clear coat before.  To add the rust i sprayed some of the clear into a small container i dipped my brush in it to wet the brush and then dipped it into the rust and then applied it to the tank
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeThu Dec 10, 2015 12:07 am
Greg so you use this as the flat finishing coat after everything is done ? It will be a lot cheaper than buying clear flat sprays from Tamiya or Testor.
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeThu Dec 10, 2015 2:40 am
yes i use it on all tanks just make sure it is the clear and not the one with the green tint in it i know Glen uses it to he is the one the first suggested using this as a flat clear for the tanks
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeThu Dec 10, 2015 8:41 am
Okay will give it a try. Thanks !
I might even have some in the basement...........
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeThu Dec 10, 2015 2:27 pm
I just went out and got some.  Sprayed  it on a cut out battery box piece and so far no adverse effects on the plastic at all. Will see again in a couple hours.  I would say though i would think it would have done something by now if it was going to since it is dry
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeThu Dec 10, 2015 3:14 pm
I am not worry about unfinished plastic. More worry about decals and also acrylic painted surfaces. Will give it a try on something I don't care much for and see what happens.
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeFri Dec 11, 2015 11:14 am
well have 2 coats on the tank and it did not bother the paint or decals. Just did not give me the effect that i was thinking it would. Beginner here thought it was going to give me that dusty look. at this point it still looks the same
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeFri Dec 11, 2015 2:53 pm
I only expected it to give a flat coat overall. If you want dusty look you might want to use Buff diluted on air brush or Testor has a spray can called Smoke. If you are not good at weathering like I do, Tamiya's paint master kits are great. You do heave to seal it after you are done, with the aforementioned frost window spray.
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeFri Dec 11, 2015 4:14 pm
Ok dumb questions. What is buff and how do you get that dusty gray look like on the tank in this post.
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeFri Dec 11, 2015 4:39 pm
Dean is the expert on weathering but this is whatI was referring to:
[img]Making my own Real Rust 8175710[/img]
Al.M
Al.M
PostSubject: Re: Making my own Real Rust   Making my own Real Rust Icon_minitimeFri Dec 11, 2015 5:37 pm
Ok great.  Dean you can chime in any time. LOL. I need to match the weathering on the T34 I bought and want the same effect on the King Tiger
» This is real hobby
» Making truck rims look better
» Making Sand Bags
» making your own barbed wire
» Real T-34s running a tank biathlon
