| Subject: VK 2002 German Prototype Wed Nov 30, 2016 8:44 pm | |
| _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: VK 2002 German Prototype Wed Nov 30, 2016 10:34 pm | |
| That's cool Jordan.......... I always like those VK series...... |
| Subject: Re: VK 2002 German Prototype Thu Dec 01, 2016 1:29 am | |
| Awesome Work Jordan that is Cool _____________________________________________ |
| Subject: Re: VK 2002 German Prototype Thu Dec 01, 2016 3:39 am | |
| Been busy doing suspension adjustments and putting some much-earned primer on! A bit on the suspension... I ground away all the existing Panzer IV mounts and roughly spaced out 6 new holes that I calculated for Panther road wheels & the length of hull I had to work with between drive sprocket and idler. Drilled out those holes & then mounted hexagonal M3-threaded standoffs, the kind that hold things together in your PC but are also popular with aircraft and drone builders.. Then I bolted some Panther suspension pieces right on! When I show this tank off I'll explain what a pain in the butt that was... let's just say for now that 10x6x3mm bearings don't just slide smoothly onto HL axles. Each suspension arm has a leaf spring that I am constantly adjusting in length. I kept it simple... I used a couple medium sized Zip-Ties® and glued them together in layers to form a spring. Voila. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
Posts : 3175 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
| Subject: Re: VK 2002 German Prototype Thu Dec 01, 2016 10:30 am | |
| I have a long barrel for this if you want it Jordan... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: VK 2002 German Prototype Fri Dec 02, 2016 4:27 am | |
| Subject: Re: VK 2002 German Prototype Fri Dec 02, 2016 7:57 am | |
| camo au naturel ! I like it ! |
Posts : 2434 Join date : 2016-06-01 Age : 51 Location : Kitchener, ON
| Subject: Re: VK 2002 German Prototype Fri Dec 02, 2016 4:33 pm | |
| Wow... those links are firm... No Sag? |
| Subject: Re: VK 2002 German Prototype Sat Dec 03, 2016 12:20 am | |
| - Jarlath wrote:
- Wow... those links are firm... No Sag?
There is a bit, but they are partially resting on a metal enclosure I fabbed up to cover the leaf springs on top. A rudimentary track guide _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: VK 2002 German Prototype | |
