Subject: Re: Modify M35A2 6x6 Mon Oct 09, 2017 11:58 am
Hach, this is the rear gearbox. You need the modified the existing end one to connect to this. You will also need to extend the frame as well with additional suspension. Might be cheaper to buy another truck to extend the frame and also get the rear gearbox and tires.
The biggest challenge is still to modify a middle gearbox for the 6x6.
The picture you have is a 1/10 version of the HC4 which is what the 1/16 is copied from.
Mike. just get some metal to extend the chassis, turn rear metal spring leaf up side down then install 2 rear axle at the end. Only thing to do is build a housing to hold spring leaf and so it can move up and down. Don't need 2nd axle to connect to main gear box. Just make it as dummy axle. That's only way to make cheap modify. And have to build a new cargo box, but it's easy.
hachleopard2 Captain
