So I purchased two T1 and one KV board from Matomart on my last order. The KV was fine as far as I can tell, but one of the T1 board will not file the cannon. Th strange part is that I can get elevation, engine start and MG, which means that it is reading that channel, but no matter what I do I couldn't get cannon fire.
Thinking it might be my radio which doesn't make sense but you never know, I swap it with the second T1 board I got, and it can fire no problem. So it is not the radio. However, then I realized that the elevation is doing really strange stuff, so I plug in the volt meter and found out that the elevation port is given out constant voltage.
My work around right now is to switch the tank to use servo elevation which is fine. I hate the Clark's motor elevation and servo elevation control anyway, but I am now worry that I have a bad batch of Clark boards.
Did I mentioned I hate Clark boards ? I am just getting used to them again, small plugs and all, after the defection to Tamiya and IBUs and now this.
I might have to start looking at Heng Long 7.1's just for playing around boards. The new guy Chris has it on the PanTiger at the March 9th meet and it worked great. Since it is only 5 hits and not adjustable I can just use them for all my mediums like Shermans etc.
