MK VII / Last Crusade WW1 Tank  Icon_minitimeby Jarlath Today at 3:29 pm
MK VII / Last Crusade WW1 Tank  Icon_minitimeby dgsselkirk Today at 3:24 pm
MK VII / Last Crusade WW1 Tank  Icon_minitimeby Hammertime999999999 Yesterday at 11:27 am
» Matomart Sale again
MK VII / Last Crusade WW1 Tank  Icon_minitimeby MikeC Sun May 05, 2024 10:59 pm
» TongDe New Tank
MK VII / Last Crusade WW1 Tank  Icon_minitimeby Abteilung 506 Sun May 05, 2024 5:48 pm
» Martin's PZ III combat god?
MK VII / Last Crusade WW1 Tank  Icon_minitimeby Abteilung 506 Sun May 05, 2024 9:39 am
MK VII / Last Crusade WW1 Tank  Icon_minitimeby dgsselkirk Sun May 05, 2024 1:52 am
MK VII / Last Crusade WW1 Tank  Icon_minitimeby dgsselkirk Sun Apr 28, 2024 5:20 pm
» Panther 1 to 1
MK VII / Last Crusade WW1 Tank  Icon_minitimeby Jarlath Sun Apr 28, 2024 3:47 pm
MK VII / Last Crusade WW1 Tank  I_vote_lcapMK VII / Last Crusade WW1 Tank  I_voting_barMK VII / Last Crusade WW1 Tank  I_vote_rcap
Go to page : 1, 2, 3  Next
MK VII / Last Crusade WW1 Tank  Empty
PostSubject: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSat Jun 23, 2012 11:20 am
This project will take a long time, I think. Just to gather the parts! I estimate I'll need 3x PnzIII sets of tracks, 2x sets of wheels (so 24 road wheels altogether) and 2 sets of sprockets, a powered pair at the rear and sort of an idler set at the front, with adjustable tension. Probably just an RX-18. Turret rotation... meh.. did the thing even rotate in the movie? Wink
I plan to have the track return over the top without any rollers, following the groove between the inner and outer hull side channels. I think that'll be fine with plastic tracks. Road wheels will ride on 7/32" brass tube, same diameter as the P3 axles. The centre deck and probably the entire 'engine compartment' will be held down by magnetic hatches for easy access. The main issue now is bracing, as this is 2mm polystyrene sheet or something similar, it is rigid but will flex under load.
Anyway, pictures!
MK VII / Last Crusade WW1 Tank  Photo022
MK VII / Last Crusade WW1 Tank  Photo023
MK VII / Last Crusade WW1 Tank  Photo024
MK VII / Last Crusade WW1 Tank  Photo021
MK VII / Last Crusade WW1 Tank  Tank
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jun 24, 2012 3:07 am
You might want to consider return rollers on the top to cut down the friction of the track.
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jun 24, 2012 6:06 pm
Stince, that's definitely a possibility, and as it looks if I can get the thing to work, I'll test it with and without return wheels. I'm not even sure if the MK VIII had them... I hope i can find a cheap supply! Wink
Anyway, new pics.
MK VII / Last Crusade WW1 Tank  Photo025
MK VII / Last Crusade WW1 Tank  Photo026
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jun 24, 2012 9:00 pm
Looking good you have to make it RC we have to have it at least drive on the field for video and pictures it's going to be cool to see finished
real_hulu
real_hulu
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jun 24, 2012 10:09 pm
well make!
But question is where are you gona to put gear box?
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSat Jun 30, 2012 12:59 am
Strato, I don't know if this any help to you, but here is a link to one some guy built as a static display. It might give you a few ideas.
http://www.hisstank.com/forum/g-i-joe-customs-finished-projects/154534-indiana-jones-mk-vii-tank.html
Check out the second page for the build pictures.
of the Pan-Tiger Panzer Div.
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSat Jun 30, 2012 9:49 pm
It belongs in a Museum.....
.... I like it ..vary cool...dont show Glen...Not German...Rolling Eyes
The Great Pan-Tiger pirat
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSat Jun 30, 2012 10:26 pm
real_hulu wrote:
well make!
The back end will be fully enclosed and the gearbox will sit right in the back. I just haven't designed that yet Wink
The length of this thing will make turning on anything other than concrete be a chore, if it works at all!
Time to go work on it some more Smile
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 01, 2012 3:36 am
New pics Smile
I secured the 'outer' sides to the main hull, with blocks of wood CA'd in between plastic sheet layers. It's about an inch gap, just enough for the PnzIII tracks to fit at the ends.
Also repositioned the side casemate guns higher up to match the movie tank. Raised the floor about 1-1/4 inches to allow more ground clearance. Phew! MK VII / Last Crusade WW1 Tank  Photo110 Front!
MK VII / Last Crusade WW1 Tank  Photo111 Bottom-rear. Attach bolts in view.
MK VII / Last Crusade WW1 Tank  Photo112 Top. Turret ring.
MK VII / Last Crusade WW1 Tank  Photo113
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 01, 2012 4:19 am
looking good looks cool what are you going to use for the gears and electronics for your side guns you might want to use the containers we use for the SLU apple then they could turn inside
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 01, 2012 6:53 am
Just because one time, I went to buy a tank from a guy but declined, because I missunderstood, he said he was selling a SHERMAN tank, not a German tank. Laughing
I'd like to see that set up with an SLU and IR and taken to Dannville Wink
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 01, 2012 6:01 pm
You think the electronics could handle the stepped up amperage from 3 IR emitters in parallel? Razz
One rotating turret. What if I could have a 'crew' who manned the casement guns independently? Bahahaha... Wink
When funds allow I'll probably stick the basic HL running gear into it, nothing fancy. The side guns are mounted in halves of a spray paint cap Wink
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 01, 2012 6:07 pm
The most import question, do you have an Indy Jones figure for it? Question
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeThu Jul 05, 2012 7:29 am
New Pics Smile
Scratch building is hard Twisted Evil Nothing on this tank is quite perfect, but it fit's nicely! Its a good mix of bits from the movie, the actual MK VIII, and stuff I'm making up.
New stuff includes tow shackles, rivet panel lines / side detailing, and that cattle bar / rack that was on the movie tank Razz
I think I might go out and buy a small piece of aluminum or steel plate for the gearbox mount.
MK VII / Last Crusade WW1 Tank  Photo114
MK VII / Last Crusade WW1 Tank  Photo115
MK VII / Last Crusade WW1 Tank  Photo116
MK VII / Last Crusade WW1 Tank  Photo117
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeThu Jul 05, 2012 7:45 am
Any chance you could bring it to the next tank battle day so we can get a first hand look ? In the pics, it looks amazing.
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeThu Jul 05, 2012 7:55 am
Looking good, Strato!
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 08, 2012 12:15 am
I am for sure bringing in next battle day Wink
By then I might have some painting done, and some moderate detail work. I need something to simulate about 10 billion rivets Wink
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 08, 2012 8:59 am
They do make scale rivets....in several different scales. I think the last time I bought them, they were in packs of 100. If your'e interested, I can probably dig up the info.
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Jul 08, 2012 9:55 pm
Did some detail work, added some plates & openings as observed in the movie. I spent some time watching Last Crusade and paused it a lot, sharpie marker in hand to highlight where things go!
Major work this time was shortening the front end of the track assembly. It was too long / too far forward, and the angle wasn't steep enough so I just hacked & sanded them down. Looks a lot better !
MK VII / Last Crusade WW1 Tank  Photo118
MK VII / Last Crusade WW1 Tank  Photo119
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Nov 11, 2012 7:45 pm
hey Strato
just wondering how this baby is going ?
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeSun Nov 11, 2012 7:56 pm
Yes Finish this baby, I will also say that Strato is in the market for PZ3 tank tracks for this project, so if you have some to sell ???
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeMon Nov 12, 2012 12:05 am
It still pretty much looks just like that!
It has the radio antenna & parascope that were visible in the movie now.
Engineering wise I have to design a good way to mount some gearbox's on it, and the Rx-18 & tracks and a few other parts...
Whats stumping me is a good way to make the front idler wheels adjustable, or under some spring tension so that they always exert a force forward, keeping the tracks taught..
Working on it!!
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeWed Nov 14, 2012 9:54 pm
Progress!
I put a coat of grey primer on, looks sharp.
Ordering a complete Pnz3 from HobbyKing, for parts (Rx-18, tracks, roadwheels). Turns out I'll only need a second set of Pnz3 tracks to equip the entire tank, so total parts cost will be under $90. Not bad.
Now I need a 5x6" piece of metal to mount the drive unit's onto... Very Happy
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeThu Nov 15, 2012 6:50 pm
LOVE IT . I saw it early this summer and was so impressed with your project
PostSubject: Re: MK VII / Last Crusade WW1 Tank    MK VII / Last Crusade WW1 Tank  Icon_minitimeThu Nov 15, 2012 8:17 pm
Im ordering some parts from MATO now, since the shipping for a P3 from Hobbyking was about $70... yikes! They don't carry HL tanks in their USA warehouse Sad
Anyway, I primed it, and took some detail photos.
MK VII / Last Crusade WW1 Tank  Img_6711
MK VII / Last Crusade WW1 Tank  Img_6712
MK VII / Last Crusade WW1 Tank  Img_6713
MK VII / Last Crusade WW1 Tank  Img_6714
MK VII / Last Crusade WW1 Tank  Img_6715
Page 1 of 3Go to page : 1, 2, 3  Next
» Older Tamiya tank kit or newer Taigan tank RTR to start out?
» RC Tank Battle AAF Tank Museum May 2017
» tank show at tank plant
» Who wants to buy a Tank?
» My first R/C tank
Can-Am RC Tank Club :: The Motor Pool (Builder's Section) :: Other Tanks and Vehicles-
