Subject: Re: Wheeled Vehicles Sun Oct 28, 2018 11:58 pm
2 speed gearbox (servo control) upgrade for the original WPL 6x6. Same 2 speed gearbox and metal transfer rod upgrade for my Katyusha which has the identical chassis as the MAN 6x6:
hachleopard2 Captain
Subject: Re: Wheeled Vehicles Mon Oct 29, 2018 7:18 am
Is this better torque?
Subject: Re: Wheeled Vehicles Mon Oct 29, 2018 7:54 am
The metal drive shafts allow for a longer center length which reduces the driveline angle (angle between the U-Joints) which lessens the U-Joint loads under torque. With a two speed transmission, you get a lower speed available with more torque. The axle differentials will be the weakest link as they see the highest torque.
Subject: Re: Wheeled Vehicles Mon Oct 29, 2018 9:25 am
That's the theory anyway, but I have not try it out yet. The gearbox I think definitely will help, since it looks like it is different sets of gears and not just a reduction on motor speed (electronically) like the new Ural truck offering which I also have and is a completely different chassis anyway. The metal transfer shafts does make the driveline more straight.
BTW the 2 speed motor is a upgraded 280 motor also.
