Custom Switch Bridge Icon_minitimeby Hammertime999999999 Today at 5:22 pm
Custom Switch Bridge Icon_minitimeby dgsselkirk Today at 3:35 pm
» Panther 1 to 1
Custom Switch Bridge Icon_minitimeby Abteilung 506 Today at 12:15 pm
Custom Switch Bridge Icon_minitimeby dgsselkirk Thu Apr 25, 2024 7:26 pm
Custom Switch Bridge Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Custom Switch Bridge Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Custom Switch Bridge Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Custom Switch Bridge Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Custom Switch Bridge Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Custom Switch Bridge I_vote_lcapCustom Switch Bridge I_voting_barCustom Switch Bridge I_vote_rcap
Custom Switch Bridge Empty
PostSubject: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeWed Jul 22, 2020 7:17 am
If you've seen my upgrading for my tanks you know that I like organized wiring and a semblance of neatness internally on my tanks.
However, sometimes I need a break from fixing up my own tanks and I get requests from some of my good friends/tankers who want some custom designed items for their tanks.
So when Dean asks me to rebuild the internal electronics for his wife's Sherman tank, I say yes! Dean's Sherman's always have their front hatches open for access to switches, except they are mounted in the upper hull which makes for a PITA when removing the upper hull. And Dean is a modeller and an artist. He is not borderline obsessive on organizational routing like I am.
Enter my fun zone. Designing and building... Huzzah!
Custom Switch Bridge Receiv11
Three design iterations for a Switch Bridge for his Mato Sherman... Top is initial concept, bottom is final design. Note the addition of screws for an assembly.
And to many they may ask why make it complicated by making it an assembly? Answer to follow.
Custom Switch Bridge Receiv10
Trial fit. Showing the epoxied in-place Mato specific Clark TK-2x/40 tray 3D printed (Provisions for mounting dual 25mm fans, but since this is using a TK-20, no real need).
Cheapo tube bender for showing the height of the switch bridge above the sponson floor (top of lower hull).
Also a 3D printed Speaker box just behind that. Volume control, Smoker toggle, and main power toggle switches on the bridge.
Custom Switch Bridge Receiv12
From this angle it is a bit easier to see why the final iteration of the switch bridge is an assembly. When the vertical parts are epoxied in place, the top can be removed if you need to service switches, or replace the drive motors. Glad I thought of that before epoxying the 2nd iteration into place.
Custom Switch Bridge Receiv13
When the upper hull is in place, the switches and volume potentiometer are just at your fingertips.
Once the complete lower is done I'll post more images of it.
PostSubject: Re: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeWed Jul 22, 2020 11:12 am
That looks great. The addition of the second functional hatch makes it all seem to come together.
PostSubject: Re: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeWed Jul 22, 2020 12:43 pm
Very cool Mike
Custom Switch Bridge Soviet10
PostSubject: Re: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeWed Jul 22, 2020 4:42 pm
Very nice! Smile
PostSubject: Re: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeThu Jul 23, 2020 6:40 am
Custom Switch Bridge P7220810
While I do not have a starting point image of the current tank. The next tank is a typical setup of Dean's.
Beautiful on the outside, a tad haphazard internally. This is the next Mato Sherman to get similar treatment/upgrading by me.
Yes those are lego/building blocks that hold the upper to the lower... (Not my doing Smile)
Custom Switch Bridge P7100811
So we'll backtrack a bit. The gutted Mato Sherman with the Clark TK-2x/40 tray installed.
Provisions for mounting dual 25mm fans, but since this was a TK-20, not needed.
Custom Switch Bridge P7100812
The highly technical concept arrangements. Battery pack and HL Speaker are being used as concept place holders while I awaited the actual speaker and Tarr smoker to install. That high-tech popsicle stick being used to determine the switch bridge dimensions and layout.
Custom Switch Bridge P7220812
Finalized locations and installation. I like my routing to be clean as F%^$. Just awaiting some brass tubing and a tube bender for finishing the smoker plumbing.
If I'm going to do it, I'm going to make it well (I hope)...
Custom Switch Bridge P7220811
Finalized lower with 3D printed trays and organizers. (That is a bridge mounted tray for a Clark TK-60 in the background)
Custom Switch Bridge P7160810
The Switch bridge uprights have multiple mounting provisions. They can be epoxied to the hull, screwed down or even held on by 5mm x 3mm magnets.
PostSubject: Re: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeMon Aug 10, 2020 7:45 pm
LOL... Finished the Lower hull of Anita 2...
Let me tell you that it IS a sexy beast inside...
Custom Switch Bridge P8100810
Yes those are brass tubes, bent to accommodate the Velcro installed Smoker.
Custom Switch Bridge P8100811
Battery area will fit almost everything including a standard hardcase LiPo. Success!
PostSubject: Re: Custom Switch Bridge   Custom Switch Bridge Icon_minitimeMon Aug 10, 2020 10:08 pm
Haphazard? You are too kind....  Razz Razz Razz
In all fairness that one was unit testing so I had not done my haphazard clean up before giving to you... Very Happy
» Useful Receiver Channel Control Light Switch
» New Bridge
» Another bridge
» Bud's new bridge!
» Bridge over...
