JST Connectors - wrong style Icon_minitimeby Smittyburger Yesterday at 11:54 pm
JST Connectors - wrong style Icon_minitimeby ZackM Yesterday at 3:31 pm
JST Connectors - wrong style Icon_minitimeby treemagnet Fri May 17, 2024 9:37 pm
JST Connectors - wrong style Icon_minitimeby Shoveler74 Fri May 17, 2024 7:07 pm
JST Connectors - wrong style Icon_minitimeby dgsselkirk Fri May 17, 2024 2:06 pm
» Super Pershing
JST Connectors - wrong style Icon_minitimeby MikeC Fri May 17, 2024 9:16 am
JST Connectors - wrong style Icon_minitimeby ZackM Thu May 16, 2024 9:55 pm
JST Connectors - wrong style Icon_minitimeby Hammertime999999999 Wed May 15, 2024 5:29 pm
JST Connectors - wrong style Icon_minitimeby HiawathaPete Tue May 14, 2024 11:41 am
JST Connectors - wrong style I_vote_lcapJST Connectors - wrong style I_voting_barJST Connectors - wrong style I_vote_rcap
Ukiewolf
Ukiewolf
JST Connectors - wrong style Empty
PostSubject: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeWed Apr 07, 2021 11:58 am
Can someone help me.  I am making some modifications to my Mato (*Newest 6.0S Henglong 1:16 TIGER I R/C Tank with Metal Upgrades and Steel Gearbox (360 Degree Rotation Turret IR and Airsoft Barrel Recoil Special Version)) and I bought some JST connectors and 2 pin male-female extensions.  Unfortunately, all of these connectors are the wrong shape and size.
Here is what I bought:
WMYCONGCONG 440 PCS 2.54mm JST-XHP 2 3 4 5 Pin Housing and Female Pin Header Terminal Connector Kit (2 3 4 5 Pin)
and
5Pcs 2Pins JST Sockets Connector Extension Cable Wire Harness for RC Battery
What SHOULD have I bought?  Many thanks again.
help Being new to this hobby, I am meeting a super group of people willing to share their knowledge and assistance.  cheers
_____________________________________________________________________________
Old_Tanker
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeWed Apr 07, 2021 12:26 pm
Quick question... are you just plugging into the 'stock' HL 6.0 controller? I suppose it also depends what you are trying to extend?
Ukiewolf
Ukiewolf
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeWed Apr 07, 2021 1:18 pm
I was initially trying to relocate my TK6.0 board and, if needed, extend any wires from the upper hull that could not reach.  The most critical was a new speaker but then new wires which I could make any length.  Unfortunately, I do not have the proper JST connectors.  (I thought I did  JST Connectors - wrong style 1f612 )
Old_Tanker
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeWed Apr 07, 2021 1:29 pm
I thought it was a standard jst 2.54 female connector. I will double check when I get home, but I'm fairly certain.
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeWed Apr 07, 2021 4:28 pm
The Amazon listing that relates to has several comments that they are not JST-XH connectors. With the latching system on them they look like JST-XA styles.
http://www.mattmillman.com/info/crimpconnectors/common-jst-connector-types/
Ukiewolf
Ukiewolf
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeThu Apr 08, 2021 4:17 am
OK.  Thanks all.  So, just to confirm, are you saying 2.54 mm JST-XH is what I need?
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeThu Apr 08, 2021 8:45 am
Yes. Majority of all connections on HL/Taigen
JST Connectors - wrong style Hlandt10
boards are JST-XH connections.
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeThu Apr 08, 2021 8:47 am
Oh on the Taigen V3 MFU, the back up tail light is not a JST-XH either (Basically every connection on the right side of the image shown is non- JST-XH)
And the sound card ribbon connector is not JST-XH (You see the 4 pin cable in the above image..).
Ukiewolf
Ukiewolf
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeThu Apr 08, 2021 10:57 am
Thanks Jarlath.  That link to Matt's Tech Pages and the subsequent pictures of MFU's has been very helpful.  Now I feel confident that the JST-XH are what I need.  I have also received a couple of crimpers and will see which one works best (PA-09 or SN-48B Ratcheting Crimping Tool).  If you have any ideas on these, please let me know.  Thanks again.
PostSubject: Re: JST Connectors - wrong style   JST Connectors - wrong style Icon_minitimeThu Apr 08, 2021 2:12 pm
Its Imperial vs Metric. 2.54mm is exactly 1/10 of an inch and 2.5mm is the XH standard in metric. They are all JST (Joint Solderless Connector) technically.
You can usually use them interchangeably. That's why some plugs are tight and some plugs just fit.
» Wrong side of the tracks!
» Wiring connectors
» COnnectors on the Clark Board
» Electrical Connectors - Typical Connections
» DEANS "T" vs TAMIYA BATTERY CONNECTORS
