treemagnet Staff Sergeant
Posts : 301 Join date : 2018-07-14 Location : Georgetown Ont
| Subject: IR LED for Tanks Sat Sep 12, 2020 6:29 pm | |
| whats the wavelength used in for the Shot LED and does anyone have a part number Tom |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 6:23 am | |
| 5mm IR Infrared Emitter LEDs (Type: T-1 3/4, 100mA) Radio Shack #2760143 • Radiant Intensity (mW): 7.8 (Typ) / 5.6 (Min) • Peak wavelength (nM): 940 • Forward voltage (V): 1.4 (Typ) / 1.8 (Max) • View angle (Degrees): 30 • Angle of half Intensity: ϕ = ± ???° • Rise/Fall Time (ns): ???
Mouser TSUS6202, Infrared Emitting Diode, 950 nm, GaAs • Radiant Intensity (mW/sr): 20/30/70 • Radiant Power (mW): 15 • Peak wavelength (nM): 950 • Power Dissipation (mW): ??? • Forward voltage (V): 1.3 (Typ) / 1.7 (Max) • View angle (Degrees): ??? • Angle of half Intensity: ϕ = ± 15° • Rise/Fall Time (ns): 800
Mouser TSAL6100, Infrared Emitting Diode, 940 nm, GaAlAs • Radiant Intensity (mW/sr): 80/170/400 • Radiant Power (mW): 40 • Peak wavelength (nM): 940 • Power Dissipation (mW): 160 • Forward voltage (V): 1.35 (Typ) / 1.6 (Max) • View angle (Degrees): ??? • Angle of half Intensity: ϕ = ± 10° • Rise/Fall Time (ns): 15
Mouser TSAL5402, Infrared Emitting Diode, 950 nm, GaAlAs • Radiant Intensity (mW/sr): 15/20/35 • Radiant Power (mW): 15 • Peak wavelength (nM): 950 • Power Dissipation (mW): 170 • Forward voltage (V): 1.3 (Typ) / 1.7 (Max) • View angle (Degrees): ??? • Angle of half Intensity: ϕ = ± 22° • Rise/Fall Time (ns): 800
Mouser 512-QED123, Infrared Emitting Diode, 880 nm, AlGaAs (peach tint) • Radiant Intensity (mW/sr): 70 (Typ) / 50 (Min) • Radiant Power (mW): ??? • Peak wavelength (nM): 890 (Typ) • Power Dissipation (mW): 200 • Forward voltage (V): ??? (Typ) / 1.7 (Max) • Emission angle (Degrees): 16° • Angle of half Intensity: ϕ = ± ???° • Rise/Fall Time (ns): 900/800
Mouser LTE-2871, Infrared Emitting Diode, 940 nm (Bin D) • Radiant Intensity (mW/sr): 8.42 (Min) @ 20mA • Radiant Power (mW): • Peak wavelength (nM): 940 • Power Dissipation (mW): 90 • Forward voltage (V): 1.35 (Typ) / 1.6 (Max) • View angle (Degrees): 16 • Angle of half Intensity: ϕ = ± ???° • Rise/Fall Time (ns): ???
Maplin Electronics YH70M, (SY-IR53A) Infrared Emitting Diode, 940nm (Tamiya Equivalent) • Radiant Intensity (mW): 35 (Typ) • Peak wavelength (nM): 940 (Typ) • Power Dissipation (mW): 100 • Forward voltage (V): 1.2 (Typ) / 1.4 (Max) • Viewing angle (Degrees): ±15° • Angle of half Intensity: ϕ = ± ???° • Rise/Fall Time (ns): ???
Everlight IR1503, Infrared Emitting Diode, 940 nm • Radiant Intensity (mW/sr): 21 (Min) @ 20mA • Radiant Power (mW): • Peak wavelength (nM): 940 • Power Dissipation (mW): 120 • Forward voltage (V): 1.2 (Typ) / 1.5 (Max) • View angle (Degrees): ±20° • Angle of half Intensity: ϕ = ± ???° • Rise/Fall Time (ns): ???
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 6:24 am | |
| I use the TSAL6100's
Tamiya is 940nM wavelength BTW. |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 7:29 am | |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 2:06 pm | |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 3:39 pm | |
| Thanks Mike I went with big mikes Led has better specs just ordered 100 of them :-) |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 4:38 pm | |
| - treemagnet wrote:
- Thanks Mike I went with big mikes Led has better specs
just ordered 100 of them :-) You can never have enough........ Is it from Digikey ? What is the product number ? I am not married to the one I bought and I am running low so will go with the better spec "gun" ! |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 5:15 pm | |
| I went with TSAL6100 digi key has them I went to alibaba long lead time but Digikey has them |
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 6:54 pm | |
| - treemagnet wrote:
- I went with TSAL6100 digi key has them I went to alibaba long lead time but Digikey has them
Sorry I couldn't find the page for you Tom, but I'm 97% sure this is the place I got mine. Having the data sheets attached to each part is the best, that's why I like good venders like them. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: IR LED for Tanks Mon Sep 14, 2020 10:42 pm | |
| A newer one is the VSLY5940. High power, narrow beam... |
| Subject: Re: IR LED for Tanks Tue Sep 15, 2020 1:58 pm | |
| - Jarlath wrote:
- A newer one is the VSLY5940. High power, narrow beam...
Wow $2.5 each ?!?!? That's like 5 times what I paid for mine. Wonder it hits 5 times better........ :-) The one Tom got is a little cheaper. only $0.80. |
| Subject: Re: IR LED for Tanks Tue Sep 15, 2020 5:10 pm | |
| I paid .23 cents from amazon little longer lead time but in no hurry |
| Subject: Re: IR LED for Tanks Tue Sep 15, 2020 6:07 pm | |
| That's the one I need to hit you from here! _____________________________________________ [b]You may be a king or a little street sweeper, but sooner or later you dance with the reaper! - Death[/b]
| Subject: Re: IR LED for Tanks Tue Sep 15, 2020 6:37 pm | |
| Subject: Re: IR LED for Tanks Tue Sep 15, 2020 7:12 pm | |
| Subject: Re: IR LED for Tanks Tue Sep 15, 2020 10:34 pm | |
| - treemagnet wrote:
- LOL need more power
Tom you know your problem is not the IR emitter...... I think I will stick with buying Canadian. Might give the $2.5 one a try. |
| Subject: Re: IR LED for Tanks Wed Sep 16, 2020 6:19 am | |
| Now guys, I could be 100% wrong on how to select these IR LED's.. Just saying that I don't fully understand Mw/sr & such... I do however want to record the IR outputs from the Clark board to determine actual V & mA that is put out. |
| Subject: Re: IR LED for Tanks Wed Sep 16, 2020 7:49 am | |
| Hey Mike how do you intend to measure the output of the IR LED? |
| Subject: Re: IR LED for Tanks Wed Sep 16, 2020 9:58 am | |
| I meant to say measure the V & I outputs with the LED in place. At least then I can hopefully get an idea if the LED is actually coming close to stated specs (assuming that I can read values during the short IR durations...)
Unfortunately there is simple quantifiable method of measuring IR emission intensity. Camera over emitter and resultant "brightness" is the subjective method. |
| Subject: Re: IR LED for Tanks Wed Sep 16, 2020 10:52 am | |
| I am working with some of the optics guys at work to measure the intensity of the ir led to see how powerful the led and test if it degrades over time and when maybe when to change it will see how it work hopefully |
| Subject: Re: IR LED for Tanks Wed Sep 16, 2020 9:17 pm | |
| Did some tests on my Sherman's TK-60S. My multimeter is not high enough quality to measure the V & I consistently... |
| Subject: Re: IR LED for Tanks Wed Sep 16, 2020 9:45 pm | |
| I am working with some of the optics people at work to come up with a way to measure the output of the IR led |
| Subject: Re: IR LED for Tanks Sat Sep 19, 2020 7:49 pm | |
| With your MG function turned on the bulb should remain bright as long as you have the trigger down. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: IR LED for Tanks Sun Sep 20, 2020 7:31 am | |
| Subject: Re: IR LED for Tanks Sun Sep 20, 2020 12:26 pm | |
| - Strato50 wrote:
- With your MG function turned on the bulb should remain bright as long as you have the trigger down.
It may appear that way, but it should be a duration (pulse) to determine hit type (MG vs Cannon) |
| Subject: Re: IR LED for Tanks | |
