Greetings all
in a bout of enthusiasm i purchased a new tank, with a what looks like 7.1 board but not sure.
then i took the entire tank apart and found not a single ball bearing anywhere, so what does one do you measure the bearings and order a few... dozen.
so what have i learned so far ?
my new tank has 6 road wheels per side, so that's 12 x 2 7x4x2mm (total 24)
my new tank has 6 idler arms per side, and they use 12 x 2 11x8x2mm (total 24)
then there is the track tensioner that takes 2 and as there are 2 that's 4 more 7x4x2 (
now does that even sound logical, 52 bearings in the drive/suspension system ?
is it just me or does that sound like a lot of bearings ?
and that's not including the gearboxes, but i have "metal" (zinc) gears and steel pins so they better last till i can afford new gearboxes or dropkick the tank into the bin.
anyone else ever done this ?
Krijn
Krijn
705th Armored Brigade. (Peterborough)
