| Is that a Unicorn or is that a Hooben Cromwell ?!?! | |
| Subject: Is that a Unicorn or is that a Hooben Cromwell ?!?! Mon Jun 28, 2021 2:31 pm | |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Mon Jun 28, 2021 2:32 pm | |
Posts : 3278 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Mon Jun 28, 2021 3:02 pm | |
| Zinc gearboxes? Looks like itty-bity Mato speaker. Metal tracks? Metal Idler and sprocket? _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Mon Jun 28, 2021 3:39 pm | |
| Looks like the Heng Long black metal gearbox. Is that Zinc ? Definitely itty-bity speaker. Plastic nylon tracks, metal sprockets and plastic idlers. Lots of 3D printed parts it appears. I will likely keep the integrated battle unit just need to figure out the wiring. It has a count system right now, when it is fully healthy all the LED will lit up, and then one by one they will go off and the tank dies when all of them are out. Kinda cute system but I don't have another Hooben to test it with. Also the MFU allows you to switch to an RC grade radio receiver combo.
Battery compartment is clever, just a cover. You plug in the battery and toss it inside. |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Tue Jun 29, 2021 8:32 am | |
| I did map out the Hooben wiring someplace... (I think when I first took apart the 1/10th Hetzer. Looks like the same MFU.) |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Tue Jun 29, 2021 8:58 am | |
| Mike if you have that would be great. I didn’t know the Hezter kept the Hooben apple. It has a IC chip to control the 5 LED and seem to share the POS+ between the IR emitter and the sensor as far as I can tell. I was just going to take the IC completely out and just use the casing and re-wire everything directly. |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Wed Nov 10, 2021 2:39 pm | |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Wed Nov 10, 2021 2:50 pm | |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Mon Nov 22, 2021 11:53 pm | |
| My version done ! Ready for battle. 20 pounder = British's 88. Way longer than I expected. Turn out Hooben's green is Tamiya TS-2. |
krijn Private
Posts : 41 Join date : 2022-12-26 Location : Peterbortough
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Tue Dec 27, 2022 3:28 pm | |
| very nice, i'm keeping my Cromwell stock for now (aside different electronics)
Krijn _____________________________________________ Krijn 705th Armored Brigade. (Peterborough)
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Tue Jan 17, 2023 8:47 pm | |
- My version done ! Ready for battle. 20 pounder = British's 88. Way longer than I expected. Turn out Hooben's green is Tamiya TS-2.
Yea that's definitely compensating for something! _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Wed Jan 18, 2023 9:31 am | |
| Well it is Wojtek compensating for something now ! Although I think he doesn't care for the Charioteer turret and would be more than happy to part with it. |
krijn Private
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Wed Jun 21, 2023 4:25 pm | |
| i do like long barrels, i have always had the feeling that them short guns are just not as powerful as same size long barreled guns, also mounting a howitzer on a tank means you just lost short range fire straight ahead as a howitzer is an "steep arch" weapon and a normal gun is "slight arch" weapon.
i did have the Cromwell with me last weekend but i did not run it, just like the M60 and several others, Hendrik did run a lot of tanks, and not all of them where ours. _____________________________________________ Krijn 705th Armored Brigade. (Peterborough)
treemagnet Staff Sergeant
Posts : 301 Join date : 2018-07-14 Location : Georgetown Ont
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Thu Jun 22, 2023 5:42 pm | |
| have the turret now if your interested |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Fri Jun 23, 2023 1:56 pm | |
| Did you buy it from Wajtek ? |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Fri Jun 23, 2023 2:05 pm | |
| LOL. Can-Am RC Tank Club, where the tanks and parts just seem to switch owners on occasion. LOL. Sometimes back to the original owner no less! |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! Fri Jun 23, 2023 2:15 pm | |
| I accuried it |
| Subject: Re: Is that a Unicorn or is that a Hooben Cromwell ?!?! | |
