Panther Turret Traverse Problem Solved  Icon_minitimeby Hammertime999999999 Yesterday at 10:49 pm
» Turrent traverse ang gun elevation for Leopard A4
Panther Turret Traverse Problem Solved  Icon_minitimeby 14goods Yesterday at 8:50 pm
» Visaton speakers
Panther Turret Traverse Problem Solved  Icon_minitimeby MikeC Sun Nov 10, 2024 10:47 am
» Little video of a battle on our last battleday of the year!
Panther Turret Traverse Problem Solved  Icon_minitimeby Hammertime999999999 Sun Nov 10, 2024 9:23 am
» Offering a ride
Panther Turret Traverse Problem Solved  Icon_minitimeby Abteilung 506 Fri Nov 08, 2024 8:46 pm
» FINAL 2024 BATTLEDAY NOV. 9TH FOR ALL THE MARBLES!
Panther Turret Traverse Problem Solved  Icon_minitimeby ZackM Fri Nov 08, 2024 12:18 pm
Panther Turret Traverse Problem Solved  Icon_minitimeby HiawathaPete Fri Nov 08, 2024 11:04 am
» Tamiya strv 122.
Panther Turret Traverse Problem Solved  Icon_minitimeby MikeC Fri Nov 08, 2024 9:25 am
» Introduction from Ray Y.
Panther Turret Traverse Problem Solved  Icon_minitimeby dgsselkirk Tue Nov 05, 2024 8:29 pm
Panther Turret Traverse Problem Solved  I_vote_lcapPanther Turret Traverse Problem Solved  I_voting_barPanther Turret Traverse Problem Solved  I_vote_rcap
spicycurrywurst
14goods
Panther Turret Traverse Problem Solved  Empty
PostSubject: Panther Turret Traverse Problem Solved    Panther Turret Traverse Problem Solved  Icon_minitimeSun Sep 02, 2012 7:51 pm
At the last meet, I had some problems with turret traverse function on No. 435
Panther Turret Traverse Problem Solved  Right_12
This particulr HL airsoft was the one I converted to IR and had to rebuild all the internal "posts" that the screws go into on virtually every part of the tank.
I was very careful and thought I got the new posts to the right height but a few were out a bit Embarassed causing some alignment problems.
I was able to fix these with washers but the turret was "drooping" in the front causing it to bind on rotation, likely also throwing the turret ring gear out of alignment as well which wouldn't help at all.
I examined it in detail and could not get the turret issues sorted out.
At the meet, Strato suggested a washer under the turret ring, good idea but it was tough to get something with all the right dimensions.
Today, I hit upon an unsophisticated solution using this product;
Panther Turret Traverse Problem Solved  Img_0811
The product has one sid that is really slippery and the other is a hard rubber backing fused to it.
I cut two pads to the right thickness (using trial and error, making sure there was still some rubber backing for the Super Glue to stick to.
I glued two pads to the upper hull in strategic locations;
Panther Turret Traverse Problem Solved  Img_0812
It produced the gap I was looking for;
Panther Turret Traverse Problem Solved  Img_0813
A skill-full repair, not really, BUT it it looks good and the turret travrse function is nou flawless Very Happy
» HL Panther turret rotation Gear box
» Binding HL RX18 2.4Ghz
» [solved]POLL - Battleday Reschedule for September 2015
» Weird problem with my Heng Long T-34
