Next Gen recoil unit... Icon_minitimeby dgsselkirk Today at 1:15 pm
Next Gen recoil unit... Icon_minitimeby MikeC Today at 12:51 pm
Next Gen recoil unit... Icon_minitimeby dgsselkirk Today at 9:09 am
Next Gen recoil unit... Icon_minitimeby dgsselkirk Yesterday at 3:35 pm
» Panther 1 to 1
Next Gen recoil unit... Icon_minitimeby Abteilung 506 Yesterday at 12:15 pm
Next Gen recoil unit... Icon_minitimeby dgsselkirk Thu Apr 25, 2024 7:26 pm
Next Gen recoil unit... Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Next Gen recoil unit... Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Next Gen recoil unit... Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Next Gen recoil unit... I_vote_lcapNext Gen recoil unit... I_voting_barNext Gen recoil unit... I_vote_rcap
Next Gen recoil unit... Empty
PostSubject: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeSun Mar 10, 2019 11:52 pm
So the JCC recoil unit is good... But I want to make it even better...
I'm in process of designing a Universal HL compact recoil system. One that can be used for Any large HL turret, as well as Panther and STUG side mounted elevation types.
Now I just need to get a Stug and Panther airsoft/recoil unit to measure against.
Next Gen recoil unit... Gen_4_10
Shifting the Servo to the opposite side, allowing usage with or without a spring impact system.
Next Gen recoil unit... Gen_4_12
Inclusion of the side elevation bars on the former servo side. Tail will be made that will be the alignment blade used on the Stugs/Panthers etc...
What I need? Anyone have old "unbroken" Stug & Panther recoil units? Donate them to me and I will give you the first working production units (sans Servo).
I need to see if I need the "Pivot" mounts to be removable... Or if they are usable in a Stug gun mount system...
PostSubject: Re: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeWed Mar 20, 2019 8:56 am
So noone has a spare (used) Stug III Airsoft unit? I find that hard to believe Smile
PostSubject: Re: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeWed Mar 20, 2019 7:22 pm
the airsoft unit is the same as all the other ones with the only difference being the tab on the back for elevation is cut off and has a slide type on the side instead
PostSubject: Re: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeWed Mar 20, 2019 10:47 pm
It looks different due to the mounting though...
Next Gen recoil unit... S5587010
Or is this an older style and all the newer ones have the pivot mounts on the unit?
PostSubject: Re: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeThu Mar 21, 2019 3:34 pm
So there ARE two styles for the Stug III... and the uppers are different... Airsoft vs IR...
Next Gen recoil unit... 000-st11
Airsoft version.... Note the pivot posts on the sides of the mechanism, and the smaller front mounted side elevation motor. No elevation alignment blade.
Next Gen recoil unit... 001-st10
Recoil/IR version. No pivot posts on the sides of the recoil mechanism, and the larger, rearward mounted elevation motor (plus the blade for alignment...)
PostSubject: Re: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeThu Mar 21, 2019 8:03 pm
When you get the Air soft version printed let me know. Ill be up for a couple . Thx
PostSubject: Re: Next Gen recoil unit...   Next Gen recoil unit... Icon_minitimeThu Mar 21, 2019 8:48 pm
I'm probably going to focus on the Airsoft version. I can only assume that the IR version is rare as hell. Anyone have qn airsoft unit from a Stug I can borrow?
» HL Recoil Unit?
» Where to buy TBU or compatible unit?
» Tamiya battle unit
» Tamiya Pershing rotation unit
» Tamiya Flash Unit
