need a little help lol Icon_minitimeby Smittyburger Sat May 18, 2024 11:54 pm
need a little help lol Icon_minitimeby ZackM Sat May 18, 2024 3:31 pm
need a little help lol Icon_minitimeby treemagnet Fri May 17, 2024 9:37 pm
need a little help lol Icon_minitimeby Shoveler74 Fri May 17, 2024 7:07 pm
need a little help lol Icon_minitimeby dgsselkirk Fri May 17, 2024 2:06 pm
» Super Pershing
need a little help lol Icon_minitimeby MikeC Fri May 17, 2024 9:16 am
need a little help lol Icon_minitimeby ZackM Thu May 16, 2024 9:55 pm
need a little help lol Icon_minitimeby Hammertime999999999 Wed May 15, 2024 5:29 pm
need a little help lol Icon_minitimeby HiawathaPete Tue May 14, 2024 11:41 am
need a little help lol I_vote_lcapneed a little help lol I_voting_barneed a little help lol I_vote_rcap
riverboat
Recruit
need a little help lol Empty
PostSubject: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 12:18 am
OK just got a Moto 1/16 tiger, tracks were on the idlers wrong so got one done do the other one tomorrow. but the nut on the tensioner is what size?? I tride 6,7 mm no good its half why between them so tried a 1/4 and a 9/32 same thing any one know what size it is?? and is there a radio up grade this matotoys black with good trim is junk would like one that i can have buttons on it to activate sound guns ex not this push the stick this why and the other one this why lol  any help would be grate thanks
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 12:38 am
Hi Riverboat,
Where are you located?
riverboat
Recruit
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 1:05 am
I live on Vancouver Island
Ukiewolf
Ukiewolf
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 7:32 am
it is 3mm - - - I bought from Amazon a set of 2 and 3mm bolts, nuts, lock washers and washers with various length bolts and replaced the short standard bolt with a much longer bolt to accommodate easier adjusting.  also, those tiny nuts and bolts like to escape and hide!!!
help Being new to this hobby, I am meeting a super group of people willing to share their knowledge and assistance.  cheers
_____________________________________________________________________________
Ukiewolf
Ukiewolf
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 7:38 am
OBTW - Brand: DANA  FRED    $22.92
Phillips Pan Round Head Machine Screw Cross Round Metric Threaded Bolts Nuts Flat Lock Washer Metal Standard Fastener Hardware SAE Assortment Kit Set 304Stainless Steel 800Pcs M2 M3
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 8:42 am
Hey Riverboat,
A couple questions and this is where images can help a lot.
You got a 1/16 Mato Tiger I correct? I assume it is a metal version? (aka metal lower hull)
Have you looked inside the tank yet? If so, do you have this inside that the idlers mount to? (Track tension adjuster set).
need a little help lol Mt192-10
Did you get this controller with it?
need a little help lol 1_309810
riverboat
Recruit
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 9:24 am
yes thats the radio that
my idler is just a nut coming through the body loosen  it up and move the arm out side it has indents
got one done last night but its like I need a 6.5 mm wrench for it
I found this radio
Turnigy 9X 9Ch Transmitter w/ Module & iA8 Receiver (Mode 1) (AFHDS 2A system
riverboat
Recruit
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 9:25 am
and yes all metal
Ukiewolf
Ukiewolf
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 10:01 am
ahhh.  all metal.  then my solution was based on a plastic tanks with TK6.0/6.1 MFU.   then the info from Jarlath is more relevant.  sorry for the misunderstanding.
PostSubject: Re: need a little help lol   need a little help lol Icon_minitimeMon Mar 29, 2021 7:06 pm
I found this radio
Turnigy 9X 9Ch Transmitter w/ Module & iA8 Receiver (Mode 1) (AFHDS 2A system)
No issues with this radio. You will have to program the buttons/switches for creating separate functions however.
Your control board will likely be a TK-22 which means that the controls are all normally controlled through 2 joysticks (4 channel control scheme to run many functions).
Two axes (one joystick) is used for track direction and steering.
The other is for multi-function controls. Turret rotation/elevation/Head light LED on-off/MG/Main Cannon/Engine on-off.
