Posts : 3377 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
Subject: Tongde Pro Churchills for sale Wed Mar 27, 2024 11:59 pm
Hey Guys,
I have ordered 4 of these awesome new Allied tanks in the pro metal version configuration. I have 2 left. I ordered 4 because that saved on shipping. I am hoping there is little or no customs on it going to try out the electronics when they arrive but of course will be looking to add a clark for battling. :-)
A chance to own another Allied tank that was unique and used by Canadian forces. I am looking forward to getting them! New TD 2.0 tank board. - Cannon recoil function, cannon flash LED with firing sound effects. - Turret rotates about 350 degrees, - Gun barrel elevation, metal barrel - Proportion smoke when driving and idling with engine sounds. - Infrared combating system. - Most hatches can open. - Front Machine gun light, sound, and rotation function. - Mantle machine gun light and sound effects. - Front lights. - On/off switch hidden in the front door. - Metal spring suspension. - Adjustable track tensioner. - Metal suspension arms. (Metal upgrade version) - Metal roadwheel set. (Metal upgrade version) - Metal idler Wheel and sprocket. (Metal upgrade version) - Metal track (Metal upgrade version) - Metal gearbox with steel gears. (Metal upgrade version)
Hammertime999999999 Major
Posts : 973 Join date : 2017-01-09 Location : Waterloo ON
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 6:36 am
And how much for electronic upgrades?
And for a cool ‘Dean custom paint’ job?
And custom Canadian decals’?
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 9:13 am
At the moment $560 cdn. Hopefully they slide through customs without getting nailed.
Clark boards tk50s will be $129 US as per Matomart. A paint job I will wait to see the tank. Decals that's easy I have lots of Brit and Canadian decals cheap!
Posts : 2523 Join date : 2016-06-01 Age : 51 Location : Kitchener, ON
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 10:41 am
Do the tensioners actually work?
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 10:43 am
Supposedly!
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 12:49 pm
Supposedly!
LOL... That does not fill me with confidence... MikeC, do your tensioners on your Crocodile actually work?
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 5:33 pm
Jarlath wrote:
Supposedly!
Yes it does. Very well I might add. The front screw (one on each side) cross thread into the idler shaft. Because it is the same shaft you could in theory adjust the two independently which would make the shaft uneven.
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 5:42 pm
Dean I will take one off you as well. Will do anther variant. I am still thinking about the Black Prince but I think it is too much work as I am suppose to widen the hull as well.
There is also this "What-If" Super Churchill. Basically a Mk VII with a Centurion turret.......
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 6:24 pm
Okay thanks Mike! I did the math on the Black prince because that was what I wanted to do too. I know the hull would have to be wider but only by 10" so converted to scale that is 15mm. I know it would be nice to do but will have to see...
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 7:08 pm
I am almost okay without widening the deck, but the sloping side fender is an issue. There is simply no room for it. Not too sure what they did with the real thing. Should have taken a closer look when I was at Bovington.
I can try to get a Comet turret which is the closest thing to it. Get our chinese friend to just print the comet turret.
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 7:55 pm
Figured it out. The Churchill idlers are mounted straight out on the side plate but the black prince is on an angled down plate. So the idler drops and allow the fender to angled down as well.
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 8:47 pm
The Black Prince would be pretty cool; doesn’t the BP have different supports for the road wheels?
Subject: Re: Tongde Pro Churchills for sale Thu Mar 28, 2024 9:13 pm
Haven't looked at it that closely but when they get here will study it more.
Subject: Re: Tongde Pro Churchills for sale Fri Mar 29, 2024 8:49 pm
Subject: Re: Tongde Pro Churchills for sale Sat Mar 30, 2024 11:14 am
I think all you need to is to flip the idler mounting plate in the front and you will be able to lower the from track fender. The extra support can be make out of styrene and glue on the side. Of course you have to get the Comet ish turret somewhere, either from Ludwig or our Chinese friend who is 3D printing every tank under the sun and he would agree to only print the turret for you.
Lots of moving parts but definitely doable.
Abteilung 506 Lieutenant
Posts : 753 Join date : 2021-03-15 Location : Toronto
Subject: Re: Tongde Pro Churchills for sale Tue Apr 02, 2024 10:55 am
I would really like to eventually get one of these but I have a self imposed moratorium this year on buying any more tanks. In the meantime I will have my totally gutted, rebuilt and repainted Jagdpanther finished soon to deal with this new threat on the field
Subject: Re: Tongde Pro Churchills for sale Wed Apr 10, 2024 4:52 pm
Supposed to be arriving tomorrow!!! Excited!
Subject: Re: Tongde Pro Churchills for sale Thu Apr 11, 2024 4:46 pm
Subject: Re: Tongde Pro Churchills for sale Thu Apr 11, 2024 5:24 pm
Will you be bringing it out to the field on Saturday? I'd like to see one running in the wild as opposed to just the internet posts of it
Subject: Re: Tongde Pro Churchills for sale Thu Apr 11, 2024 5:31 pm
yes
