Epoxy Tip of the Day Icon_minitimeby Maczek Today at 3:46 pm
Epoxy Tip of the Day Icon_minitimeby Abteilung 506 Today at 12:17 pm
Epoxy Tip of the Day Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Epoxy Tip of the Day Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Epoxy Tip of the Day Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Epoxy Tip of the Day Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Epoxy Tip of the Day Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Epoxy Tip of the Day Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Epoxy Tip of the Day Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Epoxy Tip of the Day I_vote_lcapEpoxy Tip of the Day I_voting_barEpoxy Tip of the Day I_vote_rcap
Epoxy Tip of the Day Empty
PostSubject: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeFri Oct 17, 2014 3:54 am
how many times have you used those 5 min epoxy syringe type dispensers and they don't come out evenly from each tube, then you mix them both together apply it to what you are gluing only to realize hey not having the same amount of both parts don't dry to darn quick....Epoxy Tip of the Day Mad...don't know why i didn't think of this early i guess it didn't upset me enough to do something about it, so i cut the darn sections to be on their own...now i can put the same amount from both tubes....Epoxy Tip of the Day Biggrin
Epoxy Tip of the Day Soviet10
PostSubject: Re: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeFri Oct 17, 2014 6:23 pm
sorry didn't have time to post the pic here it is now
Epoxy Tip of the Day 100_0743
PostSubject: Re: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeSat Oct 18, 2014 2:38 am
Hehe, clever Razz
You mean you just don't use the entire tube and do as many things as possible before it's gone? Hmmm this could save me hundreds of dollars.... Wink
PostSubject: Re: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeSat Oct 18, 2014 3:38 am
as one piece it never seems to come out in the same amount from each side so now i can put the same from each side evenly first one then the other then mix,   Derek said he just rocks the syringe back and forth but sometimes that works other times it still just puts more of one than the other
PostSubject: Re: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeSun Oct 19, 2014 9:31 am
Also good to know.
BTW thought there was only one version but discovered quite by accident that there are cure time versions from 90 sec to 3 hours.( in case you didn't already know)
PostSubject: Re: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeSun Oct 19, 2014 11:19 am
The marine epoxy is 2 hours, but needs 24 hours to cure.  Cures like concrete.  If you want something NEVER to come apart, use the Marine epoxy.
Epoxy Tip of the Day 0671441_1?$medium$&defaultImage=image_na_EN&wid=250&hei=250
PostSubject: Re: Epoxy Tip of the Day   Epoxy Tip of the Day Icon_minitimeSun Oct 19, 2014 11:30 am
sent you a PM Ian let me know
the tube i had was the 5 min epoxy just dollar store stuff used it to mount the hinges on the SG-122
» A Little Epoxy Tip
