Subject: Re: New tank control board for Heng Long M1A2 Abrams Thu Mar 12, 2015 6:38 pm
topher, Clark doesn't have its own IR setting. It defaults to Tamiya and so is this new board (ASP). Also, you can have the same elevation control on Clark as long as you do some re-wiring of existing HL/Taigen set-up. You can also use servo for your elevation control as well thru Clark. Here is my Strum with Clark and servo elevation for an almost 90 degree elevation:
I think the biggest advantage of the ASP board over Clark is the sound files. If you are into different sounds and more optional sounds Clark is not really a good choice. IBU2 and now ASP would give you more flexibility.
BattleArmorRC Private
Posts : 54 Join date : 2014-12-09 Location : Grande Prairie
Subject: Re: New tank control board for Heng Long M1A2 Abrams Tue Mar 17, 2015 9:48 am
No IR on the ASP.
Subject: Re: New tank control board for Heng Long M1A2 Abrams Tue Mar 17, 2015 9:54 am
Hook Up a Benedini to a Clark and you can change the engine sounds. Half of my customers are Clark users. The Clark is a Great board but the engine sounds on some of the boards need some work. The Benedini will give you great engine sounds, and nobody makes a more customizable IR board then Clark.
The Asp looks like it was designed for airsoft users.
Honestly the Clark board is so inexpensive it makes it hard for developers. I am guessing RCTA looked at a full featured board with IR, but it probably would cost twice what the Clark board sells at.
You have to design something you can sell for under $150 in this market.
Subject: Re: New tank control board for Heng Long M1A2 Abrams Tue Mar 17, 2015 11:04 pm
I see that there has been a way to add IR to this board. I wonder how much it will cost.
twain7 Recruit
Posts : 6 Join date : 2015-04-15
Subject: Re: New tank control board for Heng Long M1A2 Abrams Tue Apr 21, 2015 8:29 am
does anyone know where or who has a sound module that has turbine engine sound (without the rotor sound from a helicopter) that is proportional to match the increase and decrease of motor speed of the tank?
Subject: Re: New tank control board for Heng Long M1A2 Abrams Tue Apr 21, 2015 9:26 am
There is an Abrams version of the Clark board.
Subject: Re: New tank control board for Heng Long M1A2 Abrams Wed Apr 22, 2015 1:46 pm
Benedini has a nice Abrams file
