Strange noise with 8W amplifer? Icon_minitimeby dgsselkirk Yesterday at 8:24 pm
Strange noise with 8W amplifer? Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
Strange noise with 8W amplifer? Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Strange noise with 8W amplifer? Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Strange noise with 8W amplifer? Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Strange noise with 8W amplifer? Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Strange noise with 8W amplifer? Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Strange noise with 8W amplifer? Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Strange noise with 8W amplifer? Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Strange noise with 8W amplifer? I_vote_lcapStrange noise with 8W amplifer? I_voting_barStrange noise with 8W amplifer? I_vote_rcap
Hilario
Strange noise with 8W amplifer? Empty
PostSubject: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeSat Nov 07, 2015 1:09 pm
PostSubject: Re: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeSun Nov 08, 2015 8:15 pm
O.K. a few things. I am no expert but I know you should be using a 4 OHM with that 6 watt amp not 8 ohm. To use 8 ohm you need voltage booster. I have the feeling the strange noise you hear is because you don't have filters on those motors. If you look at HL stock motors you will see some small brown resistors on the motor terminals. Take them off and put them on your red motors and the sound should go away. also if you build little boxes around those speakers the sound will be much clearer and deeper than even this...
I am working on a sound set up for the Panther "A" that will have a DC to DC voltage booster. Going to test tomorrow night and will do some pics and video hopefully...
PostSubject: Re: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeSun Nov 08, 2015 8:50 pm
any idea what the resistance is of the small brown resistors . I thinks this may be the issue with the amp I have on Norma's KT
PostSubject: Re: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeSun Nov 08, 2015 8:54 pm
They have 104 written on them. Like I say all the time I am no expert when it comes to electronics. Maybe Jordan or Michael?
PostSubject: Re: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeSun Nov 08, 2015 10:45 pm
They are not resistors but ceramic capacitors. It is install to filter out potential electrical noise generated by the brush motors back thru the wires to the MFU.
My understanding is that if the capacitor is use that way, the value can be quite small. If all else fails just solder one from an old motor and you should be okay.
Back to the problem of the noise, it doesn't not sound like a capacitor/filtering issue. Hach, could you try trimming down the throttle on the radio (i.e. reduce the max value on full throttle) and see if the noise goes away. It sounded like the noise Clark board makes when the full throttle/trim limit doesn't match.
PostSubject: Re: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeMon Nov 09, 2015 5:37 pm
I already adjust the trim on radio. it doesn't work. This 8 watt amplifier is newer. On Clark's web showing it must have voltage booster attach to amplifier.
I had asked Clark and got his answer: This was cause by motor, will be gone when votage booster is install
I will get a 2 Ampere voltage booster from different company in 3 weeks. I will try it until Clark's voltage booster arrive
PostSubject: Re: Strange noise with 8W amplifer?   Strange noise with 8W amplifer? Icon_minitimeTue Nov 10, 2015 8:10 am
Sounds a bit like a dog's breakfast just to get better sound. You need a daughter board to run the daughter board off the motherboard. a grand daughter board ?
» Install booster and amplifier without motors noise
» Strange WWII ideas!
