Adjust output voltage on Clark booster Icon_minitimeby Abteilung 506 Today at 8:22 pm
Adjust output voltage on Clark booster Icon_minitimeby Abteilung 506 Today at 7:46 pm
Adjust output voltage on Clark booster Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Adjust output voltage on Clark booster Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Adjust output voltage on Clark booster Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Adjust output voltage on Clark booster Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Adjust output voltage on Clark booster Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Adjust output voltage on Clark booster Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Adjust output voltage on Clark booster Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Adjust output voltage on Clark booster I_vote_lcapAdjust output voltage on Clark booster I_voting_barAdjust output voltage on Clark booster I_vote_rcap
Adjust output voltage on Clark booster Empty
PostSubject: Adjust output voltage on Clark booster   Adjust output voltage on Clark booster Icon_minitimeSat Jan 02, 2016 5:24 pm
After 2 incidents. Amplifier from Clark were blow up because output voltage of booster was preset at 18 volts
https://youtu.be/rYCJ6dhlC_s
PostSubject: Re: Adjust output voltage on Clark booster   Adjust output voltage on Clark booster Icon_minitimeSat Jan 02, 2016 6:55 pm
Hach,
Why don't you run the amp off a separate battery instead of dicking around with this DC Voltage booster business ?
Mike.
PostSubject: Re: Adjust output voltage on Clark booster   Adjust output voltage on Clark booster Icon_minitimeSat Jan 02, 2016 7:28 pm
Problem is we did not know booster was preset 18 volts output and amplifier can handle only 9 volts. That why it blow up amplifier. Clark told me more voltage supply to the amp will have clear and stronger sound!? Man and Dean just install at it and destroy the amps.
You mean we should have one extra battery to run amplifier?
PostSubject: Re: Adjust output voltage on Clark booster   Adjust output voltage on Clark booster Icon_minitimeSat Jan 02, 2016 8:02 pm
Just by running two batteries you will get cleaner sound, if voltage drop is the problem for the amp. Moreover, if you run two separate battery then you can run higher voltage amps as well since they are not tied to the 7.2v or 7.4v battery with the MFU.
The input power can be completely separate for the amp. You can also do this for the smoker. We use TARR smoker and I have run it separately with a 3S lipo (11.1v).
PostSubject: Re: Adjust output voltage on Clark booster   Adjust output voltage on Clark booster Icon_minitimeSat Jan 02, 2016 11:09 pm
I will try it
» Install booster and amplifier without motors noise
» IR LED Voltage
» DIY: External Li-Po Low Voltage Cut-Off.
» 11.1 voltage for rc tank
» Clark Tk-24
