Tiger Power Second Lieutenant
| Subject: MARKING ON TANK HEAD Sat Jan 09, 2016 2:17 pm | |
| hello guys, i was wondering how you guys do the markings on the back of the tank head, i seen one member have the lion with the sheild. I was wanting to do a lightning bolt for me "blitz division" but as i tryed on my t34 looks like poop. Any ideas on a place that makes stencels or stickers per scale or even flags?
thanks guys kyle |
| Subject: Re: MARKING ON TANK HEAD Sat Jan 09, 2016 4:40 pm | |
| Subject: Re: MARKING ON TANK HEAD Sat Jan 09, 2016 6:24 pm | |
| you rock mike _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sat Jan 09, 2016 6:25 pm | |
| kevin from the ausy site wont be back till 19th grr _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sat Jan 09, 2016 6:32 pm | |
| I thought he had painted the lion on lol, do you guys know why it means same with the knight on the horse _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sat Jan 09, 2016 6:39 pm | |
| ohh do you have to print them yourself? in the desc it says makes up to 9 sheets _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sat Jan 09, 2016 7:19 pm | |
| Tiger, the Elite Armour decals are all waterslide transfers. What you see is what you get. There is enough decals to do nine different tanks, not 9 sheets of the decal. The CD they shipped with tells you the different tanks you can do with the decal sheet. |
| Subject: Re: MARKING ON TANK HEAD Sun Jan 10, 2016 12:55 am | |
| hey mike do you happen to know what the lion means? a regiment or somthing _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sun Jan 10, 2016 1:31 am | |
| Subject: Re: MARKING ON TANK HEAD Sun Jan 10, 2016 2:18 am | |
| The tiger with the shield is the insignia for schwere Panzer-Abteilung (Heavy Panzer Battalion) 506, the Charging Knight is sPzAbt 505. |
| Subject: Re: MARKING ON TANK HEAD Sun Jan 10, 2016 7:42 am | |
| I love picking your brain, thanks _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sun May 08, 2016 6:29 am | |
| - Tiger Power wrote:
That would be mine. That is from a stencil, the source is: http://www.rctank.de/TIGER-I_6 I only use markings that were actual unit markings. It is an authentic marking from S chwere Panzer-Abteilung (Heavy Panzer Battalion) 506, as Mike indicates. Actually it is a tiger.The colour of the "W" indicates the company; Green - Stab White - 1st. Red - 2nd Yellow - 3rd It seems the unwritten rule was, the cooler the unit marking, the lower the kill/loss ratio. Although Abt. did loose about 30 Tigers in one day, but that was because they were on a retreat in the Stepance-ladance sector in July 1944; this was mostly because they ran out of fuel and were blown up by the crews, not destroyed in actual battles. The Abt. 506 emblem goes on with 4 separate stencil layers; _____________________________________________ "Luck favours the prepared!."
| Subject: Re: MARKING ON TANK HEAD Sun May 08, 2016 9:28 am | |
| wow, thank you so much glen for your info. I love the tigers, great work on it. _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sun May 08, 2016 2:46 pm | |
| if your not into all the detail work painting and want a decal Peddinghaus from germany makes the best I can dig up the owners e-mail. he is a great guy and can do custom work |
| Subject: Re: MARKING ON TANK HEAD Sun May 08, 2016 2:52 pm | |
| don't go crazy but if you come across his info to let me know... always great to have possible out comes. thanks _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: MARKING ON TANK HEAD Sun May 08, 2016 3:19 pm | |
| Happened to see this, I have the site address here; http://decals.guenstigergeht.net/index.php?cat=c52_1-16-Decals-fuer-Panzer-und-Fahrzeuge-1-16-Decals-fuer-Panzer-und-Fahrzeuge.html&XTCsid=ua7fs3o2qorfgfvlurftp41846I have used these, very good quality, be careful applying them, they are fragile when wet. Once the tank is pained, I put a clear gloss coat over the area for the decals, apply them, let set for 24 hours, then spray with the same flat clear coat I use on the rest of the tank, blends in very well. I still prefer stncils, if I can get what I want in them. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: MARKING ON TANK HEAD | |
