Jaghpanther?  Icon_minitimeby dgsselkirk Yesterday at 8:24 pm
Jaghpanther?  Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
Jaghpanther?  Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Jaghpanther?  Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Jaghpanther?  Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Jaghpanther?  Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Jaghpanther?  Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Jaghpanther?  Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Jaghpanther?  Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Jaghpanther?  I_vote_lcapJaghpanther?  I_voting_barJaghpanther?  I_vote_rcap
 Jaghpanther?
Tiger Power
Tiger Power
Jaghpanther?  Empty
PostSubject: Jaghpanther?    Jaghpanther?  Icon_minitimeThu Nov 03, 2016 9:52 pm
Hey guys just wondering on my jaghpanther ,two things
1 the Bb red light..... If I take it out will it effect anything eles?
2 can I put the ir bulb in place there?
Jaghpanther?  Tank_a10
Tiger Power
Der Tiger ist auf dem losen
Jaghpanther?  Empty
PostSubject: Re: Jaghpanther?    Jaghpanther?  Icon_minitimeThu Nov 03, 2016 10:41 pm
I believe that the "Airsoft" LED is directly connected with the airsoft motor. As it spins up, you see the red light.
Jaghpanther?  Empty
PostSubject: Re: Jaghpanther?    Jaghpanther?  Icon_minitimeSun Nov 06, 2016 3:56 am
I usually cut that stuff right out and as Jar said I believe it's directly hooked up to the motor power.
Yes you can hook up your IR there, but it'd be good practice to take a 1/4" drill bit, drill out the entire hole and glue your 9-10mm tube there, thus allowing you to use something like hot glue to fix the bulb from the inside. That way you're within the rules for shot spread (It's not a shotgun) and is really easy to do maintenance on.. and paint!
Tiger Power
Tiger Power
Jaghpanther?  Empty
PostSubject: Re: Jaghpanther?    Jaghpanther?  Icon_minitimeSun Nov 06, 2016 7:09 am
Cool thanks Smile
Tiger Power
Jaghpanther?  Empty
PostSubject: Re: Jaghpanther?    Jaghpanther?  Icon_minitimeMon Nov 07, 2016 4:54 pm
This is how I installed an IR Emitter in mine, not my idea, Mike C suggested it.
It doesn't have elevation but there are no complaints on the field (except from those I am shooting at)  Laughing
The tube and bulb go in there quite nicely.
Jaghpanther?  Jagdpa10
Jaghpanther?  Empty
PostSubject: Re: Jaghpanther?    Jaghpanther?  Icon_minitimeMon Nov 07, 2016 5:13 pm
Note that your gun mantlet also does not have the "Airsoft" LED above the cannon. But interesting placement... I like it...
Jaghpanther?  Empty
PostSubject: Re: Jaghpanther?    Jaghpanther?  Icon_minitimeMon Nov 07, 2016 6:57 pm
It did, but it got "body worked" to make it look more realistic.
Jaghpanther?  Empty
Jaghpanther?
