Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby dgsselkirk Yesterday at 8:24 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Strato50's M4A3(76)W Sherman by Taigen I_vote_lcapStrato50's M4A3(76)W Sherman by Taigen I_voting_barStrato50's M4A3(76)W Sherman by Taigen I_vote_rcap
Strato50's M4A3(76)W Sherman by Taigen Empty
PostSubject: Strato50's M4A3(76)W Sherman by Taigen   Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeSat Dec 24, 2016 4:20 am
So I pulled the trigger not so long ago on Taigen's Sherman 'kit' they recently started offering in their new 76mm turret release. Naturally I got to slapping it together ASAP and even before the paint was fully cured I have something that resembles a Sherman.
First impressions were very good, it's a solid chassis that's been offered by Taigen for over a year now that was first released with the 75mm version. The kit didn't include gearboxes so I ordered a set of 4:1 reduction steel-gears with bearings. From what Ive seen so far having not run it, they are a solid set & rotate easily with hand pressure... many gearboxes normally require some effort in tweaking to get them running smoothly.
Negatives include sprocket and idler wheel caps that are VERY tough to get on. I spent about 20 minutes with a hand file getting them close & then a few cycles of on-off with a brass punch and hammer before they would mount easily. You need the cap OFF to install the idler so there isn't much tolerance for tapping while on the chassis. Remember to paint AFTER the fact... Beyond that each of my idler wheels was missing a ball bearing but Erik @ Taigen got back to me within hours letting me know new ones were in the mail. Woot.
I'll just post pictures from here on in explaining what I'm up to.
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161223_201708_zpstwflmj3z.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161223_201708_zpstwflmj3z[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161223_201747_zpsra1ndfri.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161223_201747_zpsra1ndfri[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161223_201708_zpstwflmj3z Strato50's M4A3(76)W Sherman by Taigen 20161223_201747_zpsra1ndfri[/url]
My first job was grinding out a portion of the transmission cover to allow the slightly different sized gears of the 4:1 gearbox to fit in smoothly. This isn't very unusual for different Sherman based builds and was simple enough with a dremel. Erik already gave me the heads up so no problem here.
Since I don't consider any r/c tank a true warrior until it has at least half a pound of M3 hex-head bolts in it I started drilling and tapping for the gearboxes & transmission cover. The chassis mounting standoffs are very solid and nearly the exact size for an M3 tap, so all I needed to do was drill through the hull and thread away. Fantastic. Gearboxes are now solidly mounted and I don't need to worry about crossthreading the coarse screws.
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161223_203946_zpsbh7vqn0x.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161223_203946_zpsbh7vqn0x[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161223_203946_zpsbh7vqn0x[/url]
The transmission cover was also a simple matter of drilling through the existing mounts and tapping. Now it'll never come off accidentally.
Coincidentally the suspension bogies were already tapped in M3 so where possible I installed a bolt instead of the included machine screw. There isn't enough room between the chassis and gearboxes for a bolt so the screw remains.
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161223_213750_zpsrm7w1giu.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161223_213750_zpsrm7w1giu[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161223_213750_zpsrm7w1giu[/url]
Painting begins! I set a counter sunk screw into each wheel to keep paint from fouling up the internal ball bearing and bushing surfaces. Keeps things nice and neat.
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161223_213919_zpsjumvytya.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161223_213919_zpsjumvytya[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161223_230112_zpsjys5ar87.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161223_230112_zpsjys5ar87[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_005640_zps31yvgpim.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_005640_zps31yvgpim[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161223_213919_zpsjumvytya Strato50's M4A3(76)W Sherman by Taigen 20161223_230112_zpsjys5ar87 Strato50's M4A3(76)W Sherman by Taigen 20161224_005640_zps31yvgpim[/url]
More paint... so far just a simple Canadian Tire rattle can of primer and super-flat camo green. This is a great inexpensive way to get a durable base coat onto your tanks. It's perfect for Shermans and anything Russian.
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_011046_zpslelhxle2.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_011046_zpslelhxle2[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_011706_zpsslhohbf0.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_011706_zpsslhohbf0[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_012003_zpshquz8ilq.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_012003_zpshquz8ilq[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161224_011046_zpslelhxle2 Strato50's M4A3(76)W Sherman by Taigen 20161224_011706_zpsslhohbf0 Strato50's M4A3(76)W Sherman by Taigen 20161224_012003_zpshquz8ilq[/url]
The wheel assemblies are simple and robust enough & went together in a way I haven't seen before. They have a single ball bearing on the inside rim which the long threaded axle passes through. On the outside rim & basically the entire remaining length of internal axle is a brass bushing. I assembled these adding high-speed bearing oil to each bushing and bearing & once all together they spin freely. I don't think having two bearings per wheel would have helped much & probably would only make things more complicated; the threaded axle need not be 'just right' for the wheels to spin. They can be pretty snug.
The wheels themselves are 1-piece and solid; probably indestructible. Tires are rubber and come off & on easily.
As I always do some blue lock-tight holds everything together. This stuff is essential if you want a tank that 'hardly ever' falls apart.. Wink
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_021843_zpsixn5ze1m.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_021843_zpsixn5ze1m[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_044013_zpszpj1kktk.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_044013_zpszpj1kktk[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_044107_zps30wpw1oh.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_044107_zps30wpw1oh[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161224_021843_zpsixn5ze1m Strato50's M4A3(76)W Sherman by Taigen 20161224_044013_zpszpj1kktk Strato50's M4A3(76)W Sherman by Taigen 20161224_044107_zps30wpw1oh[/url]
This is what my idler looks like after spending some time 'convincing' it to seat properly. I poached one of the bearings (Remember my set was missing one bearing per wheel) to complete a side & mount a track. The idler axle is secured with a small C-clip on the inside & then covered with the scale-looking idler adjust nut. This tank does not have functioning idler adjusters, however.
Strato50's M4A3(76)W Sherman by Taigen Pbucket
A minor downside here, but situational; the C-clips holding the idlers on are TINY and pretty fragile.. I've already had to re-bend mine after installing/removing them twice. Good luck if you drop one outside of a clean-room...! Now once you're happy with your idler setup they need not come off ever after. I'll make a point of asking Erik for a bunch of extra C-clips Wink
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_044308_zps6xkews3o.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_044308_zps6xkews3o[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161224_044308_zps6xkews3o[/url]
The tracks are nice & solid. Single pinned, just like Heng Long but without the nasty 'hollow' on the inside surface that makes that tank howl as it drives. The duckbills are a cool feature with this kit; they have a false pin that slots into portion of each link that, in a true Sherman track, would also have a pin but in this case are fixed. The special track pins have a large flat on one side that holds the duckbill on & closes each link.
PostSubject: Re: Strato50's M4A3(76)W Sherman by Taigen   Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeSat Dec 24, 2016 6:25 am
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_051833_zpsyl8fczyh.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_051833_zpsyl8fczyh[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161224_051833_zpsyl8fczyh[/url]
^^^The turret is what makes this kit a bit different as it's mostly cast metal sitting on a plastic base. The barrel is metal (aluminum? It's turned) with a brass muzzle break. Recoil is the old reliable Asiatam elevation / snap-back unit now in black plastic. They can be a bitch to wire if you're using different electronics but they're solid.
I like the small bearings that the turret rotates on; I think this is common in tamiya tanks but I wouldn't know, who buys those? Smile Basically without the turret ring gear installed you can spin the turret around with a touch and it keeps on rotating.. nice.
[url=[url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_052308_zpswguamzuz.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_052308_zpswguamzuz[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_052318_zpszqdsj09l.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_052318_zpszqdsj09l[/url] [url=https://smg.photobucket.com/user/Strato50/media/Taigen Sherman M4A3 76/20161224_052332_zpstluqvdvu.jpg.html]Strato50's M4A3(76)W Sherman by Taigen 20161224_052332_zpstluqvdvu[/url]]Strato50's M4A3(76)W Sherman by Taigen 20161224_052308_zpswguamzuz Strato50's M4A3(76)W Sherman by Taigen 20161224_052318_zpszqdsj09l Strato50's M4A3(76)W Sherman by Taigen 20161224_052332_zpstluqvdvu[/url]
With some basic paint it's starting to look alright! Upper hull appears to be a standard HL Sherman with Taigen turret gearbox inside. I don't plan on changing much here, I like the paint as is and the colour. Maybe some stencils. The harsh angles of this turret and M4A3 hull really pop out Smile
Nothing at all is wired yet and I haven't decided on a control board.. Benedini? Who knows..
PostSubject: Re: Strato50's M4A3(76)W Sherman by Taigen   Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeSat Dec 24, 2016 10:01 am
I did some touchups of the black overlay and added a bit to the turret, I'm right on the edge of thinking I added too much but a painter is never truly happy, right?
Strato50's M4A3(76)W Sherman by Taigen 20161224_095849_zpsx5lr6qia
Strato50's M4A3(76)W Sherman by Taigen 20161224_095908_zpsgeo3x2nr
PostSubject: Re: Strato50's M4A3(76)W Sherman by Taigen   Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeSat Dec 24, 2016 12:17 pm
That turret is sweet. I am not a big fan of Shermans in general but this is very nice.
I know Dean is crinching right now but I use the same two Canadian Tires grey primer for metal and the flat camo olive green for base coat. That stuff is absolutely amazing and I swear dries in 2 minutes flat.
PostSubject: Re: Strato50's M4A3(76)W Sherman by Taigen   Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeSat Dec 24, 2016 1:10 pm
looking Good
does that primer hold up on metal parts or does it scratch off
is it the armor coat can do you have pics of the cans
Strato50's M4A3(76)W Sherman by Taigen Soviet10
PostSubject: Re: Strato50's M4A3(76)W Sherman by Taigen   Strato50's M4A3(76)W Sherman by Taigen Icon_minitimeSat Dec 24, 2016 4:45 pm
Yea the armor coat is one of the primers I use.
I tend to ignore the 'cure for 24 hours' bit a lot of the time, so yea paint scratches off if I'm working on something like sprockets or wheels... meh. I also used whatever we had leftover at work, a polyester filler-primer but I forget what that was...
Yea the green camo paint dries so fast you can watch it cure, handle parts in a couple minutes!
