lesteryz Lance Corporal
Posts : 65 Join date : 2015-06-28 Age : 58 Location : Port Colborne
| Subject: ibu2 install in taigen Sun Feb 05, 2017 7:27 pm | |
| Has anyone installed a ibu2 board in a taigen. Having trouble installing all the upper hull connections. There is info on their site but no video. Dont want to screw it up it is an expensive board. There is a extra wire harness for taigen I also ordered but came with no instructions. |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 8:09 pm | |
| Mike has been playing around with them, he should be able to help you. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 8:38 pm | |
| Les, which plug are you talking about ? IBU2 is plug and play 100% with Heng Long and Taigen. You just need to make sure it is the right plug, no re-wiring of any kind needed.
Just pick up a used IBU3 as well so have been trying that out. Have about 4-5 IBU2 Base/Pro installed. My T-90 was running on it and so was the Sherman Firefly at the last couple of meets. |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 9:53 pm | |
| Does your recoil work ? There is an 8 pin and a five pin coming fro the upper hall where does the 5 pin plug in, I think it comes from recoil. |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 10:07 pm | |
| Which Taigen tank do you have ? Is this the new BB recoil ? If so only the IBU3 will work with it out of the box. |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 10:19 pm | |
| Asiatam recoil with ibu2 board |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 10:37 pm | |
| Les, can you send some pictures ? The 8 pin should go into the 8 pin, the 5 pin depends on where it is coming from, it could be the Xenon flash, or the IR. Either way, if you keep your connections the Asiatam recoil should work as is (you still have a power feed directly connected to the witch, right ?). |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 10:43 pm | |
| Yes the power feed is connected, I will send you sum pics tomorrow have to go to work |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 10:50 pm | |
| Plugged into cn3 on clark board sight , so it is the gun flash and the 4,5 pin is not used , so I dont even use it, I think my problem is solved I will try it tomorrow. |
| Subject: Re: ibu2 install in taigen Sun Feb 05, 2017 11:03 pm | |
| This doesn't help because you can't see how the wires are connected thru the 360 but it does showed that it will work........ Credit - Not my picture. Just got it off the web. |
| Subject: Re: ibu2 install in taigen | |
