| Subject: SturmTiger! Thu Feb 21, 2019 10:52 pm | |
| Upper hull acquired... |
| Subject: Re: SturmTiger! Fri Feb 22, 2019 12:46 am | |
| Is that resin ? Wow never seen one like that before. |
treemagnet Sergeant
| Subject: Re: SturmTiger! Fri Feb 22, 2019 7:40 am | |
| Subject: Re: SturmTiger! Fri Feb 22, 2019 2:35 pm | |
- Is that resin ? Wow never seen one like that before.
Mato Upper from Matomart (I put the discount card to use!). It's pretty highly detailed. Comes with the loading crane too. |
| Subject: Re: SturmTiger! Sat Feb 23, 2019 5:50 pm | |
| Interesting. So what material is it ? I am pretty sure the original Mato doesn't use this type of material. |
| Subject: Re: SturmTiger! Sat Feb 23, 2019 10:35 pm | |
| It looks like a resin. I'll have to have Dean have a look at it. |
AL Lance Corporal
Posts : 78 Join date : 2013-07-02 Age : 59 Location : New Brunswick
| Subject: Re: SturmTiger! Sun Feb 24, 2019 6:14 pm | |
| Whats the interior look like?
Any electronics?
Thanks
AL |
| Subject: Re: SturmTiger! Wed Feb 27, 2019 8:47 am | |
| The vision block "hatch" on the upper structure roof pops off akin to a hatch. The loading crane arm. The only opening hatch is the rear hull one. The grab bars are sooo fragile, I'll need to make out of metal and replace them... The Money Shot! Kaboom! That barrel is almost an inch in diameter on the inside! Rooftop angle. The large rectangular hatch is not functional. The gun mount has both elevation and traverse. Elevation is a side mounted rotating style (Panther/Sherman/Stug), but the traverse is a sideways mounted elevation cam. (Push/pull). This upper is a LED/IR version. There is a single IR Receiver/LED on the harness on the back of the upper (Under the vision block "hatch"). It looks like a resin, but the gun and traverse/elevation unit looks to be the same material. So maybe a cheaper plastic? |
| Subject: Re: SturmTiger! Wed Feb 27, 2019 8:50 am | |
| I'm thinking that I can link up 2-3 HID LED units and fit them around an upgraded Tamiya IR Emitter (In a tube) inside the barrel. Make it a REALLY bright flash... |
| Subject: Re: SturmTiger! Wed Feb 27, 2019 9:20 am | |
| Mike, I actually created a sound files for the rocket launcher for my strumtiger. I can see if I can find it for you. It combines the launch/firing sound and the rocket travel sound. |
| Subject: Re: SturmTiger! Wed Feb 27, 2019 9:44 am | |
| I remember asking you about them so long ago |
AL Lance Corporal
| Subject: Re: SturmTiger! Fri Mar 01, 2019 9:32 am | |
| Subject: Re: SturmTiger! Fri Mar 01, 2019 4:47 pm | |
| Mike, what's your email address ? I can send the file to you. |
| Subject: Re: SturmTiger! | |
