Jebus I seem to be waist deep in the KT building business with the numbers of them I do (I feel almost like Dean's Sherman Factory... Almost...)
Yes some of these images are a repost from the aluminum mounting plate thread...
A build for Hammertime999999999999999999 (or however many 9's it is. LOL).
The offensive PoS factory tray with warping already... Tank is pretty much brand new....
M3x12 standoffs already screwed in from the outer hull side. The same four corners as the old screws, plus a 5th one in the centre.
New aluminum plate roughed in place.
Screws are loose fit in place to do rough component arrangement.
Where things will roughly sit.
Layout completed. Speaker box created and installed with volume control. Front hull brace installed. TK-80 in elevated and spaced mounting tray.
Smoker located and velcro'd in place.
Power switch will be under the main deck hatch.
Lower hull completed. Switch installed, smoker installed and routed. Tracks re-installed. All lower hull testing is completed. I do like a tidy lower hull.
Removable magnetized IR emitter (connection is under the loader's hatch), and Tamiya Base installed under commander cupola cover.
The inside guts. Removed the old gun mount and installed the latest JCC recoil unit. High intensity cannon flash, and yes those are M2 bolts securing the Tamiya Battle Unit mount in place (in addition to adhesive...)
Barrel being installed (more adhesive! MORE!)
