| Subject: HL/WBL/Whatever Truck info Sun Dec 23, 2018 9:01 pm | |
| Looking to get some measurements from the rear axle of one of these trucks... What size are the drive hexes? 6mm? Or 1/4" What is the distance between the end to end of the white drive axle? As well as the outer black housing? Outside black to outside black? What is the distance between the mounting holes on the axle? Many thanks! |
| Subject: Re: HL/WBL/Whatever Truck info Mon Dec 24, 2018 11:06 am | |
| As Measured: Hex - 4.89mm, mm, 0.193 in Outside black - 104.92mm, 4.130 in Outside white - 127.57mm, 5.021 in Inside wheel - 5.17mm, 0.204 in, 10mm deep |
| Subject: Re: HL/WBL/Whatever Truck info Mon Dec 24, 2018 11:24 am | |
| Thank you. Exactly what I was looking for. |
| Subject: Re: HL/WBL/Whatever Truck info | |
