Object 704 Icon_minitimeby MikeC Today at 10:51 am
Object 704 Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
Object 704 Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Object 704 Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Object 704 Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Object 704 Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Object 704 Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Object 704 Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Object 704 Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Object 704 I_vote_lcapObject 704 I_voting_barObject 704 I_vote_rcap
 Object 704
Object 704 Empty
PostSubject: Object 704   Object 704 Icon_minitimeThu Jul 04, 2019 7:45 pm
Picked this one up not long ago. Juckenburg resin upper. Henglong lower with metal tracks. Had Taigen MFU and metal gearboxes. Barrel is fixed at the moment. Someday I'll give it proper recoil, elevation and traverse. Wanted to make it a runner so I am installing an IBU2U I had originally for the IS3. So far I've reinforced the hull with glass and resin. Also added a raised battery tray and added hold down magnets. Once I get it operational, I may make the light functional, add a receiver and emitter and barrel flash.
Cheers
Object 704 6-23-110
Object 704 6-23-111
Object 704 7-3-1910Object 704 7-4-1910
Object 704 7-3-1911
Object 704 Empty
PostSubject: Re: Object 704   Object 704 Icon_minitimeThu Jul 04, 2019 11:47 pm
Nasty looking beast !
Object 704 Empty
PostSubject: Re: Object 704   Object 704 Icon_minitimeFri Jul 05, 2019 9:02 am
Interesting magnet in hull attachment points. Great 5 stage reduction motor/gearboxes, slow and torque to hell.
That barrel mount is gonna take a bit of effort if you want elevation/recoil...
Object 704 Empty
PostSubject: Re: Object 704   Object 704 Icon_minitimeFri Jul 05, 2019 9:30 pm
Yeah. Getting that barrel free and not messing anything else up is gonna be a challenge. Hence why I will worry about it in the future!  thumbs up
As for the magnets, that is where the screws holding the hulls together were. One of the rear holes had to be filled in a little as the hole was too close to the edge.
The IBU2U can support a 3 cell lipo so that is what I will be using. Power? Check. The 2 cell in the pic was just for trial and setup cause it was what I had charged.
Object 704 Empty
PostSubject: Re: Object 704   Object 704 Icon_minitimeFri Jul 05, 2019 11:01 pm
On the subject of lipo battery, I highly recommend anyway that has the option to use 3S rather than 2S should give it a try. If you think you 2S lipo last much longer than NiMH, you should see 3S........
Object 704 Empty
Object 704
