| Subject: 88mm ammo kit Fri Feb 21, 2020 2:24 pm | |
BarryC Lance Corporal
Posts : 71 Join date : 2016-01-27
| Subject: Re: 88mm ammo kit Fri Feb 21, 2020 3:11 pm | |
| Too Cool!! Now if they would do a:
M829 120mm, APFSDS-T I'd be all in!! |
| Subject: Re: 88mm ammo kit Fri Feb 21, 2020 11:52 pm | |
| Barry, I thought Americans can pick some of that up at their local Home Depot, no ? |
| Subject: Re: 88mm ammo kit Sat Feb 22, 2020 7:49 am | |
| Nope, 30mm is the limit! |
| Subject: Re: 88mm ammo kit Sat Feb 22, 2020 10:37 pm | |
| Subject: Re: 88mm ammo kit Fri Mar 13, 2020 10:58 am | |
| So far thanks to Airbrushler........... Comes with stencil for markings and need to think about how to make it weighted without damaging the plastic or have the bottom fall out. |
| Subject: Re: 88mm ammo kit Tue Mar 24, 2020 11:33 pm | |
| Another update from Airbrushler........ |
| Subject: Re: 88mm ammo kit Wed Mar 25, 2020 9:51 pm | |
| I couldn't resist either. So here is mine. For some weight I added about 10 kg play sand. Before I sealed the primer I drilled a 5/8 hole which allowed me to pour the sand in and then super glue the pin. I have seen them in photos but until you see the scale, well, I never really appreciated the size of the shell. |
| Subject: Re: 88mm ammo kit Wed Mar 25, 2020 11:10 pm | |
| Oh wow nice......... How did you glue the bottom ? It is soft ABS plastic and I worry about it not holding the weight of the sand. That would be the cheapest and easiest solution. |
| Subject: Re: 88mm ammo kit Thu Mar 26, 2020 12:26 pm | |
| That's awesome!! _____________________________________________ [b]You may be a king or a little street sweeper, but sooner or later you dance with the reaper! - Death[/b]
| Subject: Re: 88mm ammo kit Thu Mar 26, 2020 1:18 pm | |
| LOL... Now we just need to borrow Oshawa's 88. |
| Subject: Re: 88mm ammo kit Sun Apr 05, 2020 4:53 pm | |
- Oh wow nice......... How did you glue the bottom ? It is soft ABS plastic and I worry about it not holding the weight of the sand. That would be the cheapest and easiest solution.
Apologies Mike for the long delay. I sanded the contact points for the projectile and the fire pin with gap filling Cyanoacrylate ( crazy type glue )Seems to hold very well. |
| Subject: Re: 88mm ammo kit | |
