Posts : 3066 Join date : 2013-08-25 Location : Toronto, Ontario
| Subject: Drive shaft width Tue May 19, 2020 9:27 am | |
| So I got these flanged ball bearing that measure ID 8mm and OD 22mm to try on my T-90 chassis (One for my T-72B and one for my MS-90). Turns out that the plastic chassis opening is 20mm, so no biggie, but then I realized that the drive shaft is just over 8mm (8.06mm). So anyone has any idea how I can fit this ? What are my chances of sanding down the shaft evenly by about 0.6mm over all ? No chance in hell ?
Bigger question is how. |
BarryC Lance Corporal
Posts : 71 Join date : 2016-01-27
| Subject: Re: Drive shaft width Tue May 19, 2020 12:56 pm | |
| Hi Mike, I've done it using my lathe and sandpaper. Barry |
| Subject: Re: Drive shaft width Tue May 19, 2020 1:14 pm | |
| Well I don't have a lathe so that's the end of that....... |
| Subject: Re: Drive shaft width Tue May 19, 2020 1:47 pm | |
| Just realized that if I run the gearbox with a sand paper then it is kinda like a lathe.......... :-) |
| Subject: Re: Drive shaft width Tue May 19, 2020 2:22 pm | |
| Hey Barry, what did you use on the lathe ? Metal sand paper or just regular sand paper ? |
| Subject: Re: Drive shaft width Tue May 19, 2020 6:07 pm | |
| Hey Mike,
I used wet dry, Aluminum Oxide.
I would try using a drill maybe before using the gearbox assuming you have a drill that runs pretty true.
Barry |
| Subject: Re: Drive shaft width Tue May 19, 2020 6:27 pm | |
| Barry worked like a charm. I just run the gearbox and then wrap a sand paper around the shaft and off we go. Only took about 5 mins on each side ! |
| Subject: Re: Drive shaft width Tue May 19, 2020 6:57 pm | |
| _____________________________________________ |
| Subject: Re: Drive shaft width Tue May 19, 2020 8:02 pm | |
| Subject: Re: Drive shaft width | |
