FLW200 Remote Weapoin System Icon_minitimeby Abteilung 506 Today at 9:52 am
» Martin's PZ III combat god?
FLW200 Remote Weapoin System Icon_minitimeby Shoveler74 Tue Apr 30, 2024 7:04 pm
FLW200 Remote Weapoin System Icon_minitimeby dgsselkirk Sun Apr 28, 2024 5:20 pm
» Panther 1 to 1
FLW200 Remote Weapoin System Icon_minitimeby Jarlath Sun Apr 28, 2024 3:47 pm
FLW200 Remote Weapoin System Icon_minitimeby MikeC Sun Apr 28, 2024 12:51 pm
FLW200 Remote Weapoin System Icon_minitimeby dgsselkirk Sun Apr 28, 2024 9:09 am
FLW200 Remote Weapoin System Icon_minitimeby dgsselkirk Thu Apr 25, 2024 7:26 pm
FLW200 Remote Weapoin System Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
FLW200 Remote Weapoin System Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
FLW200 Remote Weapoin System I_vote_lcapFLW200 Remote Weapoin System I_voting_barFLW200 Remote Weapoin System I_vote_rcap
FLW200 Remote Weapoin System Empty
PostSubject: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeMon May 18, 2020 5:23 pm
Got this from Carson at DKLM a while ago and finally got a chance to put it onto my Leo 2A6. It is quite a neat 3D printed model with full servo elevation and rotation capable. However, the rotation is way too fast with the small motor and the wires for the elevation servo cannot be slip ring unfortunately. I have them wired up but will have to figure out a way to slow the rotation motor. Tried to use a separate ESC from the IBU board with the same receiver but there is some cross talk but might try a dual receiver set-up and see how it goes. I also have the MS-90 remote weapon system from Carson for comparison. Full 360 rotation as there is no elevation servo wire to worry about !
FLW200 Remote Weapoin System Dscn2726
FLW200 Remote Weapoin System Dscn2727
FLW200 Remote Weapoin System Dscn2728
PostSubject: Re: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeMon May 18, 2020 5:49 pm
PostSubject: Re: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeMon May 18, 2020 6:59 pm
I was looking for something that I can adjust with a rotation knob so all these would be way too fast still.
PostSubject: Re: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeMon May 18, 2020 7:22 pm
What about a constant rotation servo. Have it set as a 2 or 3 position momentary on your remote? You would have to use a winch controller as well. Or something similar.
PostSubject: Re: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeMon May 18, 2020 10:19 pm
You need to add in a resistor (Potentiometer) into the power circuit (+ve) to the rotation motor to reduce the voltage input to the motor. (aka similar to needing a resistor on an LED line to reduce voltage to ~3V from 7ish V and therefore not burn out the LED).
PostSubject: Re: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeTue May 19, 2020 9:22 am
Might give that a try since I don't really need the torque (I know this resistor trick won't work on drive motors to slow them down).
PostSubject: Re: FLW200 Remote Weapoin System   FLW200 Remote Weapoin System Icon_minitimeTue May 19, 2020 2:04 pm
They do need to be sized properly.
» Sony remote
» SONY REMOTE
» sony remote
» Yinxiang Remote Instructions For Clark
» the SLU battle system
