Posts : 3278 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
Subject: Barrel smokers Wed Jul 29, 2020 4:39 pm
Just got my shipment of barrel smokers that work with Clark boards!!!
Very excited about this! Here is the installation guide for HL tanks. The Clark one will be available this weekend. This is going to add some fun to our battles!!! :-)
Subject: Re: Barrel smokers Mon Aug 03, 2020 1:11 am
So thanks to Dean I got two of the barrel smoker without the flash unit on Saturday at Mississauga. I had a chance to play with it a bit and it is just amazing how noone until now (Stanlley the man !) had thought of this.
In theory all you need to do is to have a proportional smoker, i.e. one with separate leads for the heating element and one for the pump motor. The idea is that with Heng Long BB/Recoil, you already have a mechanical motor to push the barrel/BB piston back, and then the trigger switch would release it and creating the forward motion for the recoil/BB.
So for a barrel smoker, all you are doing is hook up the pump motor to the BB/recoil motor connection, hook up the heating element to the smoker connection, and create a trigger switch. So in sequence what you have to happen is the following:
1. Smoker heating element is heated up and full of smoke waiting for the pump 2. BB/Recoil motor lead starts the pump motor 3. Trigger switch cuts the pump motor.
This is so simple and elegant it is truly amazing. Like I said in theory anyone that has a proportional smoker can DIY this, but Stanlley's heating element is very good, and the pump is the new style from Heng Long (which is actually just just an aquarium pump) which is much quieter and more efficient. Plus all the bits and pieces (like a long silicone tubing and the actual trigger switch) are all very nice, and we should support it simply for the IP. However, we all have the necessary bits in our parts bin to do this.
Subject: Re: Barrel smokers Mon Aug 03, 2020 2:46 pm
Here is the video of the first try with an IBU2U on my Chieftain, with the small kick-up recoil. For some strange reason IBU2U doesn't even need the mechanical kill switch, so all I did was hook up the smoker heater, plug the pump connection for the BB/Recoil port, use a smaller airbursh air tubing for the barrel and that is what it looks like. IBU2U has a radio switch to turn the smoker on/off so don't need the engine running either to get smoke.
Subject: Re: Barrel smokers Thu Aug 20, 2020 9:49 am
When I saw this on the field I thought I had imagined it, or perhaps it was just one of my eye floaters. But no, it really looked cool.
Subject: Re: Barrel smokers Thu Aug 20, 2020 10:30 am
Yup........The way it is suppose to with a muzzle brake I think.
Subject: Re: Barrel smokers Thu Aug 20, 2020 12:21 pm
Muzzle brakes are meant for 2 purposes.
reduction/control of recoil
Redirection of a portion of escaping gases
While the first portion is actually directly associated to the redirection of escaping gases caused by combusting propellant, the redirection is to ensure that the expelled gasses in front of the muzzle are minimized for follow up discharges (More fired shells on target). Most anti personnel snipers do not use muzzle brakes due to the gasses blowing up dirt/dust at their position during firing...
Most modern tanks also do not use a cannon muzzle brake as it interferes with discarding sabot rounds when fired. (Affects accuracy)
