The offensive PoS factory tray with warping already... Tank is pretty much brand new....
M3x12 standoffs already screwed in from the outer hull side. The same four corners as the old screws, plus a 5th one in the centre.
New aluminum plate roughed in place.
Screws are loose fit in place. to do component arrangement.
Where things will roughly sit.
Initial Images Hammer999999999.
And Yes MikeC. This plate is WAY stiffer with next to no flex.
