| Subject: Re: HEMTT 8x8 Trailer Mon Nov 15, 2021 9:09 am | |
| Hey MikeC, We had chatted briefly about magnetic connectors. I've been looking at these: |
| Subject: Re: HEMTT 8x8 Trailer Mon Nov 15, 2021 9:35 am | |
| Those looks good. Aliexpress ? I have these coming and I notice is has a little notch hoping it is directional. |
| Subject: Re: HEMTT 8x8 Trailer Mon Nov 15, 2021 10:10 am | |
| Yeah. The circular ones have pins in them to ensure alignment. I was looking at the 5 pin version. These circular ones are 13.5mm in diameter. |
| Subject: Re: HEMTT 8x8 Trailer Mon Nov 22, 2021 11:48 pm | |
| Found something that is 1/12 scale that my trailer can carry..... Now I need to another tractor to pull this. |
Posts : 3243 Join date : 2013-02-12 Age : 64 Location : Kitchener ON
| Subject: Re: HEMTT 8x8 Trailer Tue Nov 23, 2021 1:11 am | |
| I happen to have one.... :-) _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: HEMTT 8x8 Trailer Tue Nov 23, 2021 1:30 am | |
| Ed had the same you have pictured plus the 6x6 explosion proof truck... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: HEMTT 8x8 Trailer Tue Nov 23, 2021 12:59 pm | |
| He does ?!? Pictures ! Arr you sure it is not the 1/18 WPL truck with a Broder trailer ? |
| Subject: Re: HEMTT 8x8 Trailer Tue Nov 23, 2021 1:28 pm | |
| Ummm, NO! What you think I am that dumb? Lol! _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: HEMTT 8x8 Trailer Sat Dec 11, 2021 11:32 pm | |
| Subject: Re: HEMTT 8x8 Trailer Sun Dec 12, 2021 10:21 am | |
| Are those embedded magnets to hold it closed? |
| Subject: Re: HEMTT 8x8 Trailer Sun Dec 12, 2021 11:09 am | |
| Yes and they are crazy strong. After I made the cut to separate the top it is really difficult to open either side with just one hand. I might have to somehow bind the two together again and use two hands to open it.
Should probably think of something to protect the exposed parts. Maybe just a clear sheet for the generator but no idea what to do with the expose crane. Something that will mold over it and then harden perhaps. |
| Subject: Re: HEMTT 8x8 Trailer Tue Mar 15, 2022 8:05 pm | |
| Still waiting for my yellow launcher. Looks like everyone else has it except the seller I put a deposit with. She said she has the green one if I want and then I saw this today. Maybe it is okay to mix the two........ :-) |
| Subject: Re: HEMTT 8x8 Trailer Wed Mar 16, 2022 4:16 pm | |
| I wonder why they have the bog red bottle jack under the front stabilizer... I do note two things. Each missile tube is modular (aka fully stackable and not linked at all.) And the HEMTT isn't hooked up at this time... |
| Subject: Re: HEMTT 8x8 Trailer Wed Mar 16, 2022 5:12 pm | |
| Maybe the front stabilizer is not working properly. No doubt they are mixing the ones from Middle East deployment and mixed it with NATO deployment.
Hopefully I will get mine before they have to use them against the Russians. |
| Subject: Re: HEMTT 8x8 Trailer Wed Mar 16, 2022 5:55 pm | |
| You would think someone would turn into a rattle can king! _____________________________________________ [b]You may be a king or a little street sweeper, but sooner or later you dance with the reaper! - Death[/b]
| Subject: Re: HEMTT 8x8 Trailer Sun Apr 17, 2022 3:51 pm | |
| Subject: Re: HEMTT 8x8 Trailer Sun Apr 17, 2022 9:32 pm | |
| Boo to the same packaging and therefore false advertising.... Looking forwards to seeing a completed vehicle, er... trailer! |
| Subject: Re: HEMTT 8x8 Trailer Mon Apr 18, 2022 1:56 pm | |
| Going to have couple of tubes open so need some props. These will do. |
| Subject: Re: HEMTT 8x8 Trailer Tue Apr 19, 2022 1:17 pm | |
| Well it is massive. Here is the frame. Tamiya it ain't, already have to drill extra holes as L/R pieces are make the same rather than mirror image, and also some mix up pieces/holes on the firing tubes. Oh well. Dream come true to be building a Patriot missile system in this scale in metal and with electronics. Can't complain. Might have to think about the radar array as well if I can get it for cheapish. Kinda of look like I am building this from Space:1999 |
| Subject: Re: HEMTT 8x8 Trailer | |
