| Krupp Waffentrager 128mm Pak44 | |
Posts : 3052 Join date : 2013-08-25 Location : Toronto, Ontario
| Subject: Krupp Waffentrager 128mm Pak44 Mon Jan 09, 2023 12:52 pm | |
Posts : 799 Join date : 2017-01-09 Location : Waterloo ON
| Subject: Re: Krupp Waffentrager 128mm Pak44 Mon Jan 09, 2023 3:20 pm | |
Posts : 596 Join date : 2021-03-15 Location : Toronto
| Subject: Re: Krupp Waffentrager 128mm Pak44 Mon Jan 09, 2023 4:31 pm | |
| That is cool and another piece of armor I never knew existed until just now. Glad it will be on my team most of the time |
| Subject: Re: Krupp Waffentrager 128mm Pak44 Mon Jan 09, 2023 4:37 pm | |
| Don't think it ever existed other than in the German Designer's mind, like many other things. Even the one that was on the drawing board was based on 38T bogies and sprockets, so Ren took some liberties there. There is also one very similar I think it is based on the E-100 lower so more like KT bogies.
Trumpeter has a kit for it in 1/35.
Also forgot Ren has a Tk-40 in it with S-bus which I don't use, so if anyone is looking for a Tk-40 S-bus only please let me know and will part with cash consideration.
| Subject: Re: Krupp Waffentrager 128mm Pak44 Sun Feb 05, 2023 10:53 am | |
| Subject: Re: Krupp Waffentrager 128mm Pak44 Sun Feb 05, 2023 2:28 pm | |
| That looks really nice. Going to be interesting to see it running around the field. Those figures are really nicely painted. I need to find some for the Sturmtiger as it crying out for a diorama now I have it's shells |
| Subject: Re: Krupp Waffentrager 128mm Pak44 Sun Feb 05, 2023 2:46 pm | |
| It will be a nice runner. Everything Ren touches runs better. The Churchill, the T28/95 all ran better after he got his hands on them. This one you can tell just from the sound it will be fine......... I make a custom apple mount for it so it will be able to battle.
I have to disable the limited traverse because the gunner gets caught but I can disable if I needed to. |
| Subject: Re: Krupp Waffentrager 128mm Pak44 Tue Feb 07, 2023 10:12 am | |
| The crew really completes it. Just needs a pail hanging off it! |
| Subject: Re: Krupp Waffentrager 128mm Pak44 | |
