| Heng Long gearbox motor pinion | |
| Subject: Heng Long gearbox motor pinion Sun Oct 08, 2023 10:58 am | |
| Anyone has some extra lying around ? The pot metal gearbox motor pinion gear. I will also consider plastic gearbox pinion as well. I needed a pair and I have one of each right now for my Sherman. Runs okay but want to make sure it is evenly wearing on side.
It is actually an original Tamiya plastic gearbox but the 10T Heng Long ones actually fits to my amazement. |
| Subject: Re: Heng Long gearbox motor pinion Mon Oct 09, 2023 10:14 pm | |
| I likely have a few. I'll check. I'm looking for a HK 6ch TX Programming cable... |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 9:47 am | |
| I got one. I will trade you for it ? |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 9:48 am | |
| What can you do with it ? I must have used it long ago. |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 11:04 am | |
| I need it to program a older HK 6channel remote that I want to use with the Puma. |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 11:07 am | |
| These do for you? You just want the pinions off the motors? I can heat and remove several of them (I have installed them onto motors as well). The plastic gears were spares for Victor's KT when it finally dies..., but I do not need an excess of motor pinions... |
| Okay I also google it and I remember now. I actually have a T6A radio as well but I am selling it with other tanks so I truly has no use for it.
I might tinker with it before I send the radio off. Either way it is yours. Let me know when you need it. I can ship it to you too. |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 11:08 am | |
| Yeah perfect. Can you just make sure that it is 10T ? |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 11:09 am | |
| Don't you have a pinion remover ? |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 12:23 pm | |
| Yes I do have a puller.
I'll check and ensure they are 10t pinions and pull two for you. PM your addy so I can mail them.
Please ship whenever. Sooner the better. |
| Subject: Re: Heng Long gearbox motor pinion Tue Oct 10, 2023 1:03 pm | |
Hilario Recruit
Posts : 1 Join date : 2024-04-07
| Subject: Re: Heng Long gearbox motor pinion Sun Apr 07, 2024 4:52 am | |
| There are many on the STEPPERMOTOR.FRÂ website, you can check them out. |
| Subject: Re: Heng Long gearbox motor pinion | |
