Pershing Motor/Gearbox  Question? Icon_minitimeby dgsselkirk Today at 10:07 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby Abteilung 506 Today at 7:46 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Pershing Motor/Gearbox  Question? Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Pershing Motor/Gearbox  Question? I_vote_lcapPershing Motor/Gearbox  Question? I_voting_barPershing Motor/Gearbox  Question? I_vote_rcap
Pershing Motor/Gearbox  Question? Empty
PostSubject: Pershing Motor/Gearbox Question?   Pershing Motor/Gearbox  Question? Icon_minitimeSat Jun 02, 2012 4:23 pm
I wanted to check with the Pershing owners in the club to see what they are using for motors and gearboxes.
I am wondering if the HL Pershing, with stock running gear and plastic tracks needs. or will significantly benefit with other motors or gearboxes.
I find that I prefer the Tiger I's with 3:1's but am not sure how the stock Pershings run in comparison, due to their sprocket size differing from the Tiger's.
PostSubject: Re: Pershing Motor/Gearbox Question?   Pershing Motor/Gearbox  Question? Icon_minitimeSun Jun 03, 2012 12:46 am
Glen, I don't have a Pershing myself, but I have read on other forums that because of the drive sprocket being a different size that you get more torque out of the stock gearboxes. They supposedly act like 3:1's.
of the Pan-Tiger Panzer Div.
PostSubject: Re: Pershing Motor/Gearbox Question?   Pershing Motor/Gearbox  Question? Icon_minitimeSun Jun 03, 2012 6:30 pm
Mine has stock gears and runs well, ask to try it next time Glen.
The Great Pan-Tiger pirat
PostSubject: Re: Pershing Motor/Gearbox Question?   Pershing Motor/Gearbox  Question? Icon_minitimeSun Jun 03, 2012 10:05 pm
mine has stock metal gears and maetal tracks but it's not a battle tank as of yet so i don't run it and didn't even bring it to the last battle
PostSubject: Re: Pershing Motor/Gearbox Question?   Pershing Motor/Gearbox  Question? Icon_minitimeSun Jun 17, 2012 8:51 am
Happened to find this on RC Tankwars
Bulldog / M-26 / KV- 1 Steel Gearbox & 480 Motors
HL Steel Gearboxs with the 480 motors, that drops right into our Bulldog, Pershing or KV-1. This setup is the standard gearing combine this with the smooth strong steel gears and 480 motors should make for excellent speed, power & torque. You will increase your top end speed and add the torque with the Promax 480s without the need for gearing down.
It is one of the higher cost units, at $105.00 but is sounds like a high quality product.
PostSubject: Re: Pershing Motor/Gearbox Question?   Pershing Motor/Gearbox  Question? Icon_minitimeSun Jun 17, 2012 9:00 am
I think this the set Tetris put in his Bulldog.
» Heng Long gearbox motor pinion
» Motor Question?
» Asiatam 3-1 Gearbox vs Steel HL gearbox
» My Gearbox Issue
» Gearbox Cleaning?
