| Servos Question for Clarks | |
| Subject: Servos Question for Clarks Thu Aug 29, 2013 11:23 am | |
| For my T-34 I'm planning on using a Clark board with servos for the elevation and for the recoil. I'm a little uneducated when it comes to servos. Is there a certain type/size I should be looking for?
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 1:51 pm | |
| Is it a WSN like mine ot the Torro? _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 6:13 pm | |
| I went with the standard sub-micro, HS-55's. Usually between $10-20 _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 6:25 pm | |
| I think I used an HS-81 for Dean's T34....... " /> |
shiivers01 Private
Posts : 16 Join date : 2013-05-09
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 8:12 pm | |
| Im actually running my elefant on those same servers and i will be adding one to my tiger. The movement looks a lot better. |
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 8:51 pm | |
| - dgsselkirk wrote:
- Is it a WSN like mine ot the Torro?
Is there a difference? As far as I know they are the same copy of each other just under different names. Oh, and was a WSN. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 8:53 pm | |
| Will these work okay? They sell them at the local hobby shop, for $5. Features Dimensions: 22*11.5*27mm Operating Speed (4.8V no load): 0.12sec/60 degrees Stall Torque : 1.2kg / 42.3oz(4.8V);1.6 kg / 56.4oz (6.0V) Temperature Range: -30 to +60 Degree C Dead Band Width: 7usec Operating Voltage:3.0-7.2 Volts Original box: NO Net weight: 14g Package weight: 20g _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 9:01 pm | |
| I just bought 4 of those for $20 too. Haven't use them yet but they will work I am sure. Same size as the HS-81 I used on the WSN.
BTW, I think WSN also sells the Tiger/T34 as static models but Torro is only RC. |
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 9:07 pm | |
| OK here is the skinny on servos for the Clark 2 types Analog and Digital, for a Clark board - Who cares. The board don't, it's an equal opportunity user. The two gear types are plastic and metal. Use metal if you can afford them as you get longer life out of them which equals less maintenance and they are much stronger and run truer. Plastic gears strip when things come in contact with your barrel or your moving your tank around and you push it. if you are lucky and buy a name brand replacement parts are available or you can buy servos for 5 bucks and just replace them. Think that is a bad thing? sometimes no because the teeth of the servo can act as a safety- meaning that when something does hit your barrel its much easier to replace a $5 servo than all the guts etc holding the barrel in.
Stince That servo will work fine but when you buy it make sure it comes with arms.
Me i switched to metal servos but that is because I am a dumb azz and keep forgetting to turn my KT barrel sideways when I go through ditches, stripped 3 servo already this year lol |
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 9:54 pm | |
| Thanks for the info Curtis, I'll try to get out to the hobby shop this weekend and maybe see what they have that I can use for the steering for the Half-track too.
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 9:56 pm | |
| Curtis that just means your barrel is too big... I know I knew, I can hardly believe it too... _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 10:53 pm | |
| Hey Curtis, the HS-55 or HS-81 are only plastic gears, right ? I mean unless you go for the $30 jobs you won't get metal gear, no ? If it is all plastic anyway, I would take the no name $5 instead of the $15 HiTec ones. |
| Subject: Re: Servos Question for Clarks Thu Aug 29, 2013 11:12 pm | |
- Hey Curtis, the HS-55 or HS-81 are only plastic gears, right ? I mean unless you go for the $30 jobs you won't get metal gear, no ? If it is all plastic anyway, I would take the no name $5 instead of the $15 HiTec ones.
Mike I have 9.99 tower pro servos in stock, they are metal gear servos If all you guys want I can mass an order from each of you in the same pot and get them for like 6 or 7 bucks including shipping costs. It will take about 2 weeks to get here but they are great metal geared servos. About the same size as the HS81 but I can get a micro version for the same cost for those little tanks we all have. |
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 12:38 am | |
| Alright Curtis, bring me couple when we meet up and I will try them out. They look and measure slightly bigger than the Tower Pro SG-90 and the HS-81. Do they have a stronger pull ? |
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 1:56 am | |
| - Freakydude wrote:
Me i switched to metal servos but that is because I am a dumb azz and keep forgetting to turn my KT barrel sideways when I go through ditches, stripped 3 servo already this year lol hehehe or going through Stince's Barn _____________________________________________ |
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 1:59 am | |
| Curtis i won a HiTec HS-425BB Servo Deluxe with dual ball bearings would that be good for a recoil _____________________________________________ |
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 6:34 am | |
| - Airbrushler wrote:
- Curtis i won a HiTec HS-425BB Servo Deluxe with dual ball bearings would that be good for a recoil
Thats a nice servo, good price too @ servo city for $12.99. Too bad their shipping is insane... _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 7:58 pm | |
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 8:37 pm | |
| yes it would work just make sure you set your end point adjustments. A full 180 deg of turn is actually what you don't want for recoil as the servo can move too much. It will be smooth as silk though once you get your distances done and set |
| Subject: Re: Servos Question for Clarks Fri Aug 30, 2013 10:07 pm | |
| Hi Curtis did you mean the one i have or the one Derek is thinking is the speed on this one a good thing it has a 0.21 sec/60degrees AT 4.8 volts _____________________________________________ |
| Subject: Re: Servos Question for Clarks Sat Aug 31, 2013 9:05 am | |
| - Freakydude wrote:
- OK here is the skinny on servos for the Clark
Me i switched to metal servos but that is because I am a dumb azz and keep forgetting to turn my KT barrel sideways when I go through ditches, stripped 3 servo already this year lol sorry i just read this post again ....my last post was based on one of my i just woke up from falling asleep at the computer things...lol thanks for your answer Curtis _____________________________________________ |
| Subject: Re: Servos Question for Clarks | |
