Knupfer for hardware  Icon_minitimeby MikeC Today at 10:51 am
Knupfer for hardware  Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
Knupfer for hardware  Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Knupfer for hardware  Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Knupfer for hardware  Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Knupfer for hardware  Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Knupfer for hardware  Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Knupfer for hardware  Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Knupfer for hardware  Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Knupfer for hardware  I_vote_lcapKnupfer for hardware  I_voting_barKnupfer for hardware  I_vote_rcap
Hilario
Knupfer for hardware  Empty
PostSubject: Knupfer for hardware    Knupfer for hardware  Icon_minitimeTue Oct 29, 2013 3:48 am
http://www.knupfer.info./
Where Adman Shops
Knupfer for hardware  Soviet10
PostSubject: Re: Knupfer for hardware    Knupfer for hardware  Icon_minitimeTue Oct 29, 2013 12:16 pm
Seem to be pretty expensive although I like the selection. I have a good one from the States. Will post online tonight...
PostSubject: Re: Knupfer for hardware    Knupfer for hardware  Icon_minitimeTue Oct 29, 2013 8:42 pm
Here are the guys I got from either this or rctankwarfare forum:
http://www.microfasteners.com
PostSubject: Re: Knupfer for hardware    Knupfer for hardware  Icon_minitimeWed Oct 30, 2013 7:47 pm
My supply is also from the U.S....nice people
http://www.scalehardware.com
PostSubject: Re: Knupfer for hardware    Knupfer for hardware  Icon_minitimeThu Oct 31, 2013 3:48 pm
Thanks Ian will check out that one too......
PostSubject: Re: Knupfer for hardware    Knupfer for hardware  Icon_minitimeWed Nov 27, 2013 12:38 pm
For reference, if you are building 1/16 scale tanks and want to use the correct scale hardware, here is a list of 1/16 scale to full size reference chart I found on the net.
ROD
.08 (16) = 1.28, equivalent to 1-1/4" tubing
.100(16) = 1.60, equivalent to 1-5/8" tubing
TUBING
.093(16) = 1.48, equivalent to 1-1/2" tubing
.125(16) = 2.00, equivalent to 2" tubing
.156(16) = 2.496, equivalent to 2-1/2" tubing
.188(16) = 3.008, equivalent to 3" tubing
Threaded Hex Bolts
.8 mm threaded hex bolt, Hex head = .042", Dia. = .031", Length = .100" equivalent to a 1/2" bolt
1.00 mm threaded hex bolt, Hex head = .055", Dia, =.039", Length = .140" equivalent to a 5/8" Bolt
1.1 mm threaded hex bolt, Hex head = .055", Dia. = .043", Length = .140" equivalent to a 11/16" Bolt
1.2 mm threaded hex bolt, Hex head = .078", Dia = .047", Length = .315" equivalent to a 3/4" Bolt
1.4 mm threaded hex bolt, Hex head = .078", Dia. = .055", Length = .315" equivalent to a 7/8" Bolt
1.6 mm threaded hex bolt, Hex Head = .096", Dia. = .063", Length = .394" equivalent to a 1" Bolt
00-90 threaded hex bolt, Hex head =.078", Dia. = .047", Length = .500" equivalent to a 3/4" Bolt
00-80 threaded hex bolt, Hex head = .091", Dia = .058", Length = .500" equivalent to a 15/16" Bolt
Simulated Hex Bolts
.7 mm Simulated hex bolt, Hex Head = .028", Dia. = .016", Length = .118" equivalent to a 7/16" Bolt
.85 mm Simulated hex bolt, Hex head = .033", Dia = .020", Length = .118" equivalent to a 5/16" Bolt
1.0 mm Simulated Hex Bolt, Hex head = .039", Dia = .020", Length = .157" equivalent to a 5/16" or 3/8" Bolt
Hope you find this useful.
PostSubject: Re: Knupfer for hardware    Knupfer for hardware  Icon_minitimeWed Nov 27, 2013 1:46 pm
Now that is a great bit of intel Thx
Can-Am RC Tank Club :: The Quartermaster's Depot :: Vendors-
