Got this one from Zach. Dragon I believe but it is the ready built version and not the kit. Interestingly enough actually has steering wheel linkage, so once you hook up a servo for steering, you get the steering wheel movement as well. HobbyWing 880 ESC and two direct drive gearbox. I thought I did the math correctly with the wheel diameter and 20km actual speed but clearly 62RPM is too slow. I will return them when the 100RPM ones shows up. Will see if that works out. Will bring it out to Oshawa to complement Dean's KT.
Hammertime999999999 Major
Posts : 978 Join date : 2017-01-09 Location : Waterloo ON
