Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby dgsselkirk Today at 10:07 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby Abteilung 506 Today at 7:46 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 I_vote_lcapPanther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 I_voting_barPanther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 I_vote_rcap
Go to page : Previous  1, 2, 3  Next
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Empty
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeFri Jul 06, 2012 1:52 pm
Some more repair ramblings;
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0429
The Vernier Calliper is a handy measuring tool
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0430
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0431
Measuring the height of an original post. The new one has to be the same height if the hull top and bottom are to fit together properly.
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0432
Arrow shaft fits the outside of the post, cut the post off, leaving the bottom half to use as a locator and to glue the arrow shaft to. This is the outer shaft and must be shorter than the required height of the post.
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0433
Choose and arrow shaft that will fit the recess in the upper hull post, cut a piece to a length that will make the new post up to the height of the original post.
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0434
Glue the inner tubing into the outer shaft, fill with JB Weld and drill a pilot hole in the JB Weld when it has set, the screw will cut new threads in the JB Weld. It is quite strong, likely tougher then the original.
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeFri Jul 06, 2012 2:00 pm
Lots of broken things in this one.
The three little posts that hold the turret traverse unit were done for.
I could not repair them so I left their remains as locating pins and made a clamping arrangement.
It can still be removed with a screw driver and replaced with a stock unit, if needed.
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0435
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0436
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeFri Jul 06, 2012 6:50 pm
Very MacGyver of you Glen. geek
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 MacGyver_c_49416
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeSat Jul 07, 2012 2:09 pm
Finally.
I am starting into the modifications for the IR/SLU installations, rather than fixing broken stuff cheers cheers
Soon I will want to start practising to see if I can produce those very thin lines with my airbrush for the camo pattern I want to use.
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeSun Jul 08, 2012 10:21 am
I have settled on a camo pattern after adjusting and testing my airbrush.
I will be able to produce the thin, squiggly lines for the "Lake Balaton" pattern. Very Happy
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Panthe18
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Panthe19
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeTue Jul 10, 2012 9:44 pm
3:1's and the Flash Unit showed up today from Mato, I ordered them Friday; they got here earlier than I expected.
The 3:1's look very good, I test ran them and they ran well, everything fits quite well in the hull.
I ordered a receiver tonight from Hobby Hobby, that is the last mechanical or electrical part I required.
Now I am getting close to start painting. Very Happy
But, I need to clean up the wheels a bit more, first.
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeTue Jul 10, 2012 9:53 pm
lets see a before and after Glen if possible
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeThu Jul 12, 2012 6:18 am
No problem, I have the "before " pictures on file and will definitely take the "after" Wink
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeFri Jul 13, 2012 8:43 pm
Painting has begun Very Happy
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeSun Jul 15, 2012 9:38 am
Found an example of the style of number I need for the Panther Very Happy
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 435_pi10
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeSun Jul 15, 2012 12:24 pm
ok i couldn't keep the email open long enough to get the picture but i copied it from here so i will see how it goes in reproducing it from the pic you had here i'll let you know how it goes damn viruses
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeSun Jul 15, 2012 3:00 pm
Thanks Very Happy
The project is going along quite well, the yellow will be done today, then the camo starts so I am getting closer to having it ready for markings.
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 18, 2012 8:35 pm
Painting is under way.
Here are a few pictures.
Bear in mind, there's no weathering, no accessories, no clear coat, no markings......................and, the camera doesn't show the true colours under the lights.
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0443
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0513
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0514
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 18, 2012 8:42 pm
looking pretty damn awesome Glen
great job
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 18, 2012 8:51 pm
Did you just show us a naked Tank?!?! Shocked Embarassed
Glen there are children here! Advert our eyes Captain Action! No
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 18, 2012 8:54 pm
My tanks wear ""Stencils by Airbrusher" (TM), or they wear nothing at all Wink
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 18, 2012 9:12 pm
hehehe
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 18, 2012 9:20 pm
You should see his "Allies Collection", you'll be green with envy! Very Happy
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeSat Jul 21, 2012 10:47 pm
Airbrusher brought the stencils to the July 21st meet, THANKS Very Happy
As usual, they are excellent, I look forward to applying them to the Panther.
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 25, 2012 6:48 pm
I was working out of town on Monday and Tuesday but I am back and the stencils are going on tonight Very Happy
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 25, 2012 6:49 pm
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 25, 2012 8:31 pm
Stencils, as delivered;
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0522
Here they are painted, they still need weathering and clear coat, etc. but I am very pleased with them Very Happy
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0523
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0524
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0525
Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Img_0526
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 25, 2012 8:46 pm
i like the camo on this tank Glen great job it looks cool can't wait to see it finished
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 25, 2012 9:06 pm
I hope to have it at the August meet.
Thanks for the comments on the camo, I wasn't sure going into it if I could "gitter done"
Funny thing about the stencils, before application, they give the illusion of being too big, once the paint is on and the stencil removed, the size is PERFECT
of the Pan-Tiger Panzer Div.
PostSubject: Re: Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR   Panther G, HL. Rebuild Of My 2010 Airsoft To SLU/IR - Page 2 Icon_minitimeWed Jul 25, 2012 10:11 pm
I like the camo too add lots of detail and may be try a little weathering on this one, I think it would blend together well.
The racing numbers look just about the right size to me, no name on this one ?? aww...
The Great Pan-Tiger pirat
Page 2 of 3Go to page : Previous  1, 2, 3  Next
» T-34 rebuild
» LAV III - Rebuild Project
» The Gearhead Automotive Rebuild Thread
» Airsoft Gun, HL, Looking for One
» Henglong airsoft gun
