| SLU Installation in a Panzer IV F2 ???????? | |
| Subject: SLU Installation in a Panzer IV F2 ???????? Tue Aug 21, 2012 8:32 pm | |
| I have been looking at ways to convert a Pz IV to IR, SLU and came up with these ideas; Cut the lower airsoft unit off, leaving the upper part of the gun to support the barrel and mantlet and engage the elevation (I did this in the last Panther), this gives enough vertical room for the SLU. I would have to be happy with just the track recoil, but I can live with that. Install a flash. Set the components up as shown in the picture. Not sure if the emitter would go in the mantlet or if I would use an external, barrel mounted emitter. I will be working on the Jagdpanther first, this is just some abstract forward thinking for a later project. It would use a tank I already have, it is a good airsoft shooter but there doesn't seem to be much call for airsoft around here, these days. I would look at a repaint on this one and maybe a few things like turret skirts. This is what it looks like now, Grossdeutschland colours/markings, Russia, Spring 1942. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 8:05 am | |
| I always wonder why I hardly ever see PnzIV's on ANY tank battlefield! Maybe other commanders don't like the suspension, I don't know, I think they do and can look awesome. Glen, your's looks great already The dimensions being overall similar yet a little bigger than the Panzer III means you'll have a bit more room to work with. I set my P3 up the same way as Hulu and Stince did, with the SLU in the far rear. It might help to cut away the battery box, seal it, and just mount the batteries internally. Depends on how easy you can change them. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 8:17 am | |
| - Strato50 wrote:
- . Glen, your's looks great already
Thanks, I am not 100% sure I'd re-finish, I just like painting them I chose not to repaint my next project, the Jagdpanther and will just convert it and touch it up a bit. That was because it was an authentic scheme and I was happy with it. I did this one in GD colours because it was an authentic camo on a machine that did not have skirts; I thought the skirts might be a bit fragile and in the way on a model that was driven a lot. - Strato50 wrote:
The dimensions being overall similar yet a little bigger than the Panzer III means you'll have a bit more room to work with. I set my P3 up the same way as Hulu and Stince did, with the SLU in the far rear. It might help to cut away the battery box, seal it, and just mount the batteries internally. Depends on how easy you can change them. Yeah, that layout I marked up is backwards to the normal installation, I will have to look a bit closer, I have time, this would be a future, winter project. Basic "worst case" component dimensions are; SLU 3 5/8" x 2 7/8" x 1" ESC 3.3" x 2" x 1" _____________________________________________ "Luck favours the prepared!."
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 9:24 am | |
| Great timing , I have been working to get a Panther ready for sat but the tank choosen for my second SLU upgrade was my Airsoft PZ IV. Thanks for your insights on how to cram all that stuff into it . |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 9:49 am | |
| </A>" border="0" /> And here is a shot of my PZ IV ,It a Taigen without the details |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 12:01 pm | |
| - knispel wrote:
- Great timing , I have been working to get a Panther ready for sat but the tank choosen for my second SLU upgrade was my Airsoft PZ IV. Thanks for your insights on how to cram all that stuff into it .
In my opinion, getting enough depth for the components is key. I am used to using the existing battery boxes and so I don't take that route. The Panther seems large but the room inside is wide and long but shallow, that's why I took the different approach of cutting down the airsoft unit, nothing projects below the turret floor, then. This takes up less room than a recoil unit; I can live with the flash and the track recoil. In regards to gearing, a wise man (Captain Action) said consider leaving the stock gears in, knowing my liking for 3:1's in the "cats" because the Pz IV would benefit form the speed. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 8:31 pm | |
| - Strato50 wrote:
- I always wonder why I hardly ever see PnzIV's on ANY tank battlefield!
I am not sure, but I don't read about many of them, either. IIRC there aren't any IR Pz Iv's at the Can Am. I confess a liking for the "cats" and my perception is that a Tiger(I or II), Panther or Jagdpanther with 3:1's do better under poorer ground conditions than something smaller (though this may be proven wrong). I am still thinking of mine for a future project, though. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 8:39 pm | |
| I like the Taigen, is it all R/Céd up? Here's a few more of mine; _____________________________________________ "Luck favours the prepared!."
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 9:25 pm | |
| I believe Tim has a Panzer IV, but I don't know if it's IR. I would like to get one some day and convert it to Jagdpanzer IV. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 9:41 pm | |
Stinger Captain
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 10:18 pm | |
| Pz IV is one of the few tanks I don't have and would like to get, so it's on my shopping list...did I hear somone say the hobby show is coming up. Sounds like a great time to pick up a Pz Iv. (or two)
Stinger _____________________________________________ My Tanks <<== Click hereCan-Am Tank Club <<< Web site linkTiger I | King Tiger | Panther G | PzIII | PzIV | Stug IV | SturmTiger | Pershing/Howitzer | M16 Halftrack | M26 Super Pershing | M48 Patton | M41 Bulldog | Gepard | Leopard | KV-1 | KV-2 |T-34 | |
TeTris MoNk Sergeant
Posts : 238 Join date : 2012-03-22 Age : 30 Location : Sudbury, ON
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Wed Aug 22, 2012 10:24 pm | |
| After doing my Bulldog there is no way in hell I'm gonna touch another small tank with an SLU ....yet my dad has a Pz. IV and he wants it IR'd >.< |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Thu Aug 23, 2012 3:23 am | |
| Tetris, that isn't nearly yellow enough! _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
Stinger Captain
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Thu Aug 23, 2012 9:38 am | |
| - Strato50 wrote:
- Tetris, that isn't nearly yellow enough!
Yea, that's just looks terrible....he should sell it to me...hehehehe Stinger _____________________________________________ My Tanks <<== Click hereCan-Am Tank Club <<< Web site linkTiger I | King Tiger | Panther G | PzIII | PzIV | Stug IV | SturmTiger | Pershing/Howitzer | M16 Halftrack | M26 Super Pershing | M48 Patton | M41 Bulldog | Gepard | Leopard | KV-1 | KV-2 |T-34 | |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Thu Aug 23, 2012 10:54 am | |
| You sure its gotta be more yellow? And Stinger.... you trying getting a DAK tank away from Erwin Rommel. (yes my grandpa named him that...) |
Stinger Captain
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Thu Aug 23, 2012 11:22 am | |
| Great pic ! Time to start building a desert cammo set of tanks. That looks great. I'm starting on gathering the pieces I need to make the Bovington Tiger I right now...seems a Pz Iv will need to join it...lol _____________________________________________ My Tanks <<== Click hereCan-Am Tank Club <<< Web site linkTiger I | King Tiger | Panther G | PzIII | PzIV | Stug IV | SturmTiger | Pershing/Howitzer | M16 Halftrack | M26 Super Pershing | M48 Patton | M41 Bulldog | Gepard | Leopard | KV-1 | KV-2 |T-34 | |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Fri Aug 24, 2012 1:32 pm | |
| I have to admit my Taigen Pz IV is so pretty that it will be hard to make the firt cuts for the SLU conversion . |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? Mon Aug 27, 2012 6:28 pm | |
| Subject: Re: SLU Installation in a Panzer IV F2 ???????? | |
